Options for setFields
Like Tree18Likes
Old   April 24, 2019, 03:28
Dokeun, Hwang
dokeun is on a distinguished road
Originally Posted by Hisham View Post
I got it. I post here for future readers.
1. In the blockMeshDict, define the cellZone names for required blocks:
e.g. (from the damBreak example)
blocks
hex (0 1 5 4 12 13 17 16) cellZoneName (23 8 1) simpleGrading (1 1 1)
hex (2 3 7 6 14 15 19 18) (19 8 1) simpleGrading (1 1 1)
hex (4 5 9 8 16 17 21 20) (23 42 1) simpleGrading (1 1 1)
hex (5 6 10 9 17 18 22 21) cellZoneName (4 42 1) simpleGrading (1 1 1)
hex (6 7 11 10 18 19 23 22) (19 42 1) simpleGrading (1 1 1)
2. In the setFieldsDict,
defaultFieldValues
volScalarFieldValue alpha1 0
regions
zoneToCell
name "cellZoneName";
fieldValues
volScalarFieldValue alpha1 1
Dear Hisham
Thank you for your post and comment for followers like me.
I'd also like to use non-box region initialization for the flow on cylinderial wall with multiphaseInterFoam.
The difference is that I import gmsh for mesh using gmshToFoam and there was no problem but I have a problem during setFields execution.
the code I have is as below.
deaultFieldsValues
    volScalarFieldValue alpha.water 1
    volScalarFieldValue alpha.air 0
    volVectorFieldValue U (0 0 0)
regions
  patchToFace
   name inlet_water;
   fieldValues
  patchToFace{...}
  patchToFace{...}
  zoneToCell
    name internal_water;
    fieldValues
      volVectorFieldValue U (0 -0.5 0)
When I run setFields then I have a error message
-->  FOAM FATAL IO ERROR:
keyword name is undefined in dictionary ".zoneToCell"
file: .zoneToCell
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 566.
FOAM exiting
But when I check the Valid type by typing errata, it recommand the zoneToCell as one of the Valid type.
I guess zoneToCell is to be applied in setFields but I didn't get any idea from tutorials which use zoneToCell. They use zoneToCell in different utilit
y other than setFields.
I solved the problem with other region option, cylinderAnnulusToCell but it is little bit annoying because I have to know the coordinates.
Is there any fault that I have tried? And how can I fix it?
Thank you in advance.
dokeun is offline   Reply With Quote
Old   July 24, 2019, 14:16
Owais Shabbir
Owais Shabbir is on a distinguished road
Hi Dokeun,
Have you found any solution to it? I am in a similar problem right now.
Thanks
OS
Owais Shabbir is offline   Reply With Quote
Old   July 25, 2019, 00:32
Dokeun, Hwang
Originally Posted by Owais Shabbir View Post
Hi Dokeun,
Thanks
OS
Hi
You might need to check the coincidence of the name for ‘set’ in refineMeshDict file and the name in the topoSetDict.
Good luck.
Old   August 22, 2019, 16:26
Default setFields for different time step
  #24
Riccardo
RANSES is on a distinguished road
Hello to everybody. I'm profiting of this open thread for asking a simple question about setFields. By default, setFields is acting on the 0 folder. Do you know if you can use it also on other time-steps (i.e. time folders)?
If yes, how?
If no, do you know if there is an alternative for doing this operation?
thank you in advance.
RANSES is offline   Reply With Quote
Old   August 22, 2019, 22:03
Dokeun, Hwang
If yes, how?
Hello, Riccardo
When I need to run OpenFOAM case for non-zero time step, there are previous data for it. No need to use setField. Just one thin to do is changing the initial time from what you want to start in ControlDict.
If you want to start a case from other data set, then you need to use mapfields.
Good luck.
Old   August 23, 2019, 05:32
Riccardo
Originally Posted by dokeun View Post
Hello, Riccardo
Good luck.
Hi Dokeun,
and thank you very much for your reply. The problem I'm facing is a dispersion study. I have to simulate a pollutant dispersion phenomenon starting from a converged state of the flow-field....that's why I want/need to apply setField on the concentration field in a time-step later than 0. I think I resolved this issue by copying the field I have modified with setField in the 0 folder in the one of the converged flow-field (kind of 2s). I was wondering if there was a "more elegant" way for doing this operation.
Old   August 23, 2019, 05:37
Assistant Moderator
Bernhard Gschaider
Hi Dokeun,
I'd say "Use funkySetFields. It has a -time-option" But I'm extremely biased
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 23, 2019, 09:14
Riccardo
Thank you Bernhard, I will give a look to it.
Also, I'm having problem at defining setFields for a volVectorField (I've bee using it just for volScalarField). Do you know if setFields can be used also for vector quantities?
Old   August 26, 2019, 08:42
Dokeun, Hwang
Hi Dokeun,
Sorry for late reply.
I’m not so sure about my opinion because I’m newbie, too.
Anyway, as I think....
You might have a solution data without particles (and BC without particle definition) already from previous calculation for improving convergence.
And the field data folder for 2s are to be stored about the same calculation domain.
Then make a new case copying previous folders and files(system, control, 2.00, mesh file)
Make a mapfieldsPar file from examples or tutorials in control folder and change initial time as 2 sec in controlDict file.
Modify SetfieldPar so as to include boundary condition for particle with previous bc.
Then, just run SetfieldsPar, mapFieldsPar, Solver.
I hope you can crack the problem.
setfields, setfieldsdict, zonetocell
Remeshing with User Defined Options ChristianF CFX 2 September 24, 2014 10:19
How do I select solver options for external flow over an aircraft by fluent? hadieliasi FLUENT 5 May 2, 2011 04:54
Post processing: Hard-copy save options and image quality beguxa FLUENT 3 November 10, 2010 18:41
It would be nice to have application options abbreviated! lakeat OpenFOAM Running, Solving & CFD 0 September 16, 2009 23:22
Surface tension options for VOF models chapelle FLUENT 4 September 20, 2005 04:49
