April 10, 2014, 12:05 |
#21 |
Ripudaman Manchanda
Rep Power: 13 |
Update on the above message:
mapFields is giving me a similar error for various other cases. In some cases mapFields randomly does not give me an error but in others it does. 1. Using a coarse blockMesh does not solve the problem 2. Using no region refinement using snappy does not solve the problem. I ran a first case with a single STL file of a plane in my coarse blockMesh grid and solved my equations. Then I mapped the results onto a grid of the blockMesh but with two surfaces (inside the blockMesh) snapped to grid using SHM. I was still able to solve my case and the results were mapped from the previous case to the current case. I ran into an error when I tried doing this for a third grid with three surfaces snapped using SHM. This time I ran into an error using mapFields which was very similar to the error mentioned in the post above : Code:
--> FOAM FATAL ERROR: Plane normal defined with zero length Bad points:(-137.15995 129.54 -7.6199818) (-137.15995 129.54 1.2356772e-05) (-137.15995 129.54 7.6200008) From function void plane::calcPntAndVec ( const point&, const point&, const point& ) in file meshes/primitiveShapes/plane/plane.C at line 116. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 Foam::plane::calcPntAndVec(Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::Vector<double> const&) in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #3 Foam::tetOverlapVolume::tetTetOverlapVol(Foam::tetPoints const&, Foam::tetPoints const&) const in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libmeshTools.so" #4 Foam::tetOverlapVolume::cellCellOverlapMinDecomp(Foam::primitiveMesh const&, int, Foam::primitiveMesh const&, int, Foam::treeBoundBox const&, double) const in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libmeshTools.so" #5 Foam::meshToMeshMethod::intersect(int, int) const in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libsampling.so" #6 Foam::cellVolumeWeightMethod::setNextCells(int&, int&, int&, Foam::List<int> const&, Foam::List<bool> const&, Foam::DynamicList<int, 0u, 2u, 1u> const&, Foam::List<int>&) const in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libsampling.so" #7 Foam::cellVolumeWeightMethod::calculateAddressing(Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, int, int, Foam::List<int> const&, Foam::List<bool>&, int&) in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libsampling.so" #8 Foam::cellVolumeWeightMethod::calculate(Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&) in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libsampling.so" #9 Foam::meshToMesh::calcAddressing(Foam::polyMesh const&, Foam::polyMesh const&) in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libsampling.so" #10 Foam::meshToMesh::calculate() in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libsampling.so" #11 Foam::meshToMesh::meshToMesh(Foam::polyMesh const&, Foam::polyMesh const&, Foam::meshToMesh::interpolationMethod const&, Foam::HashTable<Foam::word, Foam::word, Foam::string::hash> const&, Foam::List<Foam::word> const&) in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libsampling.so" #12 in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/mapFields" #13 in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/mapFields" #14 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #15 in "/opt/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/mapFields" Aborted (core dumped) Any help will be hugely appreciated. |
May 29, 2014, 15:42 |
#22 | |
Amjad
Rep Power: 14 |
Hallo, i am trying to get the internal Field values from my RANS simulation to use them as intial internal Field for LES, but the problem I always get uniform 0, can u help me pls? |
June 17, 2014, 11:40 |
mapFields issue
#23 |
Rep Power: 12 |
Hello!
I am trying to use the mapFields too. My problem is that I don't even get the following in the terminaL: *---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0 Exec : mapFields /home/Z-DRIVES/s207619/Thesis/cases/noTower_AOA_yplus/k-epsilon/prueba -consistent Date : Jun 17 2014 Time : 15:31:18 Host : "sow7503f-li.soe.cranfield.ac.uk" PID : 4730 Case : /home/Z-DRIVES/s207619/Thesis/cases/noTower_AOA_yplus/k-omega/fine_AOA7 nProcs : 1 sigFpe : Floating point exception trapping - not supported on this platform fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Source: "/home/Z-DRIVES/s207619/Thesis/cases/noTower_AOA_yplus/k-epsilon" "prueba" Target: "/home/Z-DRIVES/s207619/Thesis/cases/noTower_AOA_yplus/k-omega" "fine_AOA7" Create databases as time Source time: 75 Target time: 75 Create meshes Source mesh size: 360747 Target mesh size: 683832 It gets stacked there; I don't even get the message which says: Mapping fields for time... I have tried the suggestions in this thread but I haven't solved it yet. Does anyone have an idea or what the problem might be? Thanks in advance. |
November 18, 2014, 06:58 |
#24 | |
Per Jĝrgensen
Rep Power: 14 |
I have a similar problem
I am using SHM to generate a finer mesh contained in the coarse solution When I run mapFields I it always find a zero normal surface - I have tried to adjust the meshquality in SHM but without success Did you find a solution to your problem? Or does anyone else have a solution? Quote:
November 18, 2014, 08:57 |
#25 |
Per Jĝrgensen
Rep Power: 14 |
UPDATE: the implementation of calcAdressing has changes in 2.3
In Foam::tetOverlapVolume::tetTetOverlapVol I would expect that tet's with 3 points on a line should be caught by if ((tetA.tet().mag() < SMALL) || (tetB.tet().mag() < SMALL)) { return 0.0; } |
November 21, 2014, 05:57 |
#26 | |
Per Jĝrgensen
Rep Power: 14 |
If I make the mesh finer the problem goes away |
November 21, 2014, 15:24 |
#27 |
Seroga
Rep Power: 15 |
Hi everyone!
Does it possible in OpenFOAM to map fields between to computational domain that don't have common points at all? However the domains are topologically similar. Domain.JPG |
November 22, 2014, 06:48 |
#28 | |
Per Jĝrgensen
Rep Power: 14 |
if you use ascii the file constant/polymesh/points contain the coordinates - change these in the source geom |
November 23, 2014, 13:00 |
#29 |
Seroga
Rep Power: 15 |
Thanks for your answer, but I didn't understand what did you mean, actually...
Both domains are generated with snappyHexMesh utility for example. So the number of computational grid points are different. Could you please explain your answer in more detail? Thanks beforehand |
November 24, 2014, 04:07 |
#30 |
Per Jĝrgensen
Rep Power: 14 |
If your 2 domains overlap mapFields should work just fine even though they don't have common point. But not having common points at all I read as they are located in entirely different places in space, and in that case mapFields will not work, for it to work you need to transform your source points so they overlap your target. I am not aware of a tool that does it, so you might have to program it yourself
December 27, 2014, 02:58 |
#31 |
Ripudaman Manchanda
Rep Power: 13 |
Thanks a lot for figuring out the solution to the problem perjorgen.
Like Seroga, I am a little confused about the implementation of your solution. For your reference here are a few lines from my source and target points files. Source: Code:
189558 ( (-300 -300 -3352.84) (-270 -300 -3352.84) (-240 -300 -3352.84) (-210 -300 -3352.84) (-180 -300 -3352.84) (-150 -300 -3352.84) (-120 -300 -3352.84) (-90 -300 -3352.84) (-60 -300 -3352.84) (-30 -300 -3352.84) (-8.8294375e-20 -300 -3352.84) (30 -300 -3352.84) (60 -300 -3352.84) (90 -300 -3352.84) (120 -300 -3352.84) (150 -300 -3352.84) (180 -300 -3352.84) (210 -300 -3352.84) (240 -300 -3352.84) (270 -300 -3352.84) (300 -300 -3352.84) (-300 -270 -3352.84) (-270 -270 -3352.84) (-240 -270 -3352.84) (-210 -270 -3352.84) (-180 -270 -3352.84) (-150 -270 -3352.84) (-120 -270 -3352.84) (-90 -270 -3352.84) (-60 -270 -3352.84) (-30 -270 -3352.84) (-1.5745528e-19 -270 -3352.84) (30 -270 -3352.84) (60 -270 -3352.84) (90 -270 -3352.84) (120 -270 -3352.84) (150 -270 -3352.84) (180 -270 -3352.84) (210 -270 -3352.84) (240 -270 -3352.84) (270 -270 -3352.84) (300 -270 -3352.84) (-300 -240 -3352.84) (-270 -240 -3352.84) (-240 -240 -3352.84) (-210 -240 -3352.84) (-180 -240 -3352.84) (-150 -240 -3352.84) (-120 -240 -3352.84) (-90 -240 -3352.84) (-60 -240 -3352.84) (-30 -240 -3352.84) (-3.5706191e-19 -240 -3352.84) (30 -240 -3352.84) (60 -240 -3352.84) ... Code:
219198 ( (-300 -300 -3352.84) (-270 -300 -3352.84) (-240 -300 -3352.84) (-210 -300 -3352.84) (-180 -300 -3352.84) (-150 -300 -3352.84) (-120 -300 -3352.84) (-90 -300 -3352.84) (-60 -300 -3352.84) (-30 -300 -3352.84) (1.5276265e-07 -300 -3352.84) (30 -300 -3352.84) (60 -300 -3352.84) (90 -300 -3352.84) (120 -300 -3352.84) (150 -300 -3352.84) (180 -300 -3352.84) (210 -300 -3352.84) (240 -300 -3352.84) (270 -300 -3352.84) (300 -300 -3352.84) (-300 -270 -3352.84) (-270 -270 -3352.84) (-240 -270 -3352.84) (-210 -270 -3352.84) (-180 -270 -3352.84) (-150 -270 -3352.84) (-120 -270 -3352.84) (-90 -270 -3352.84) (-60 -270 -3352.84) (-30 -270 -3352.84) (1.1986395e-07 -270 -3352.84) (30 -270 -3352.84) (60.000001 -270 -3352.84) (90.000001 -270 -3352.84) (120 -270 -3352.84) (150 -270 -3352.84) (180 -270 -3352.84) (210 -270 -3352.84) (240 -270 -3352.84) (270 -270 -3352.84) (300 -270 -3352.84) (-300 -240 -3352.84) (-270 -240 -3352.84) (-240 -240 -3352.84) (-210 -240 -3352.84) (-180 -240 -3352.84) (-150 -240 -3352.84) (-120 -240 -3352.84) (-90.000001 -240 -3352.84) (-60.000001 -240 -3352.84) (-30.000001 -240 -3352.84) (-2.6021587e-07 -240 -3352.84) (30 -240 -3352.84) (60.000001 -240 -3352.84) ... And do you recommend writing a program that finds the minimum distance between points in the source and target and replaces the points in the target file with the points of the source file if the distance between points is less than a small number such as 1e-6? Your clarification here will be extremely useful. Thank you. Regards, Ripu |
March 31, 2015, 12:37 |
#32 |
Timm Severin
Rep Power: 12 |
I just found this thread because I also had the error and googling brought me here
--> FOAM FATAL ERROR: Plane normal defined with zero length So my "solution" right now is to temporarily switch to of22x (using alias, compare Using aliases to help manage multiple OpenFOAM versions), map my fields and revert to OF23x. Another possibility might be to port the old mapFields to OF23x, but I leave that to people who care...
PhD Student at the Institute of Biochemical Engineering at TU München Modelling of fluid dynamics in open photobioreactors. System: OpenFOAM 2.3.x, 64bit, 8 Core Xeon Workstation |
February 5, 2016, 00:26 |
#33 |
Jade Chantrell
Rep Power: 11 |
Hi ripudaman and foamers,
Have you had any development on this probelm? I have mentioned your error in this thread with a proposed solution: http://www.cfd-online.com/Forums/ope...utility-2.html I feel as if the problems I am having are very close to the problems described in this thread. I do believe 3.0x has reverted back to 2.2x functionality with mapFields. Last edited by Chanterz; February 5, 2016 at 00:28. Reason: forgot to mention something |
April 25, 2018, 06:32 |
#34 |
Peter
Rep Power: 11 |
Dear Foamers,
I also struggled some time with mapFields in version 1606 (and newer) with - three snappy meshes (of a model scale ship w/o free surface) - coarse/ medium/ fine, lowRe - # 14, 25 and 50 million cells. The problems were that either no fields were mapped (using mapFieldsDict) or that an Error (sigSegv) appeared (with option -consistent). SOLUTION: Using the option 'mapMethod' https://www.openfoam.com/documentati...8C_source.html The default entry 'interpolate' leads to the error, but both others work: - mapNearest - cellPointInterpolate Important: You need to consider the mapping-interpolation for sure... But hey, at least it works |
January 24, 2021, 13:32 |
Problem with mapping outlet velocities of once mesh to inlet patch of another mesh
#35 |
Jan Majcher
Rep Power: 8 |
Hi all,
I have two meshes, one is an extension of another. It's a kind of an inlet fetch for a logarithmic velocity profile to develop properly before it reaches my terrain geometry. An outlet of the fetch, called nnw should deliver U, k, omega for the inlet (sse) of the main mesh. I use OF6. Now, the fetch mesh refinement levels are different than that of the main mesh. The main mesh is much finer. The outlet of the fetch is exactly in the same place in space as the inlet for target mesh, but it is less refined. So I have been trying to use mapFields to impose the outlet fields of the fetch mesh into the inlet of the main, fine mesh. I have the mapFieldsDict in my target case: nnw is the outlet of the coarse fetch, sse is the inlet of the fine main mesh. Code:
patchMap (nnw sse); cuttingPatches (); value uniform (0 0 0); at the velocity inlet etc. The problem is that when I execute mapFields /path/to/source case/ -sourceTime latestTime it detects all the fields, performs interpolation but after it finishes, nothing changes. I also tried defining the inlet of the fine, target case as the cutting plane and it performed some bizarre interpolation with multiple zero values (see the screengrabs). I tried different interpolation types too, didn't help. Screengrabs: https://photos.google.com/share/AF1Q...JnVV9sNHlOYWlR Any ideas how to cope with this problem? thanks. |
January 25, 2021, 07:18 |
#36 |
Jan Majcher
Rep Power: 8 |
Well, problem solved. I simply swapped the patch names in the mapFieldsDict's patchMap.
The first one is a target patch, the second one is the source patch. To my understanding it is contrary to what is written here: https://cfd.direct/openfoam/user-guide/v6-mapfields/ I hope this helps someone who has the same problem in the future. |
March 11, 2021, 03:02 |
#37 |
anis1984
hi, I have meet the same problem with you that there is no data wrtitten in the target U file,but i solved this problem by this:
check the coordinate about the domain wheather is correspond to the domain you want, which means you need to ensure the way the map field you want dont need any extra translation or rotation. for example you want the inlet be mapped,the source geometry is at (-5 0 0) to (0 0 0), the length of x direction is 5, but your target geometry is at (10 0 0) to (15 0 0),although your geometry is totally the same size,but there is no any of coincident mapfield! that's why we won't have any data in our target field. hope this will help you anyway. Regards |
May 28, 2021, 16:59 |
#38 |
Rep Power: 12 |
Dear MaySea,
I was working on similar problem. Could you share the related cutting plane file? I've also obtained a cutting plane but when I executed the mapFields command my U file does not change. Kind Regards |
May 28, 2021, 17:29 |
#39 | |
Jan Majcher
Rep Power: 8 |
Here nnw is my receiving (target) patch and sse is my source patch. I map the outlet "sse" into inlet "nnw". The command I use: mapFields /path/ -sourceTime latestTime -mapMethod mapNearest Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object mapFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // patchMap (nnw sse); //target source //mapMethod "mapNearest" //cellPointInterpolate cuttingPatches (); // ************************************************************************* // Jan |
-consistent, mapfields, mapfieldsdict |
FLUENT Speed Issues on Cluster | cfd23 | FLUENT | 2 | April 4, 2010 00:43 |
mapFields problems | andrea.pasquali | OpenFOAM | 1 | February 17, 2010 23:57 |
mapFields ignores sourceTime for -parallel source | andersking | OpenFOAM Bugs | 2 | September 2, 2009 11:38 |
mapFields between inconsistent meshes | nikwin | OpenFOAM Pre-Processing | 7 | July 30, 2009 05:35 |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 15:17 |
