BC setting
Old   September 28, 2010, 12:50
Default BC setting
Jie (Jay) Zhang
jiez is on a distinguished road
Hi, Foamers,
I'm green hand to OpenFOAM, If I set the BC in U as fellowing:
inlet
type massFlowRateInletVelocity
massFlowRate 1.2// 1.2kg s^-1
What should I do with the same BC in P. It is incompressible flow, P can be calculated from U.
Thanks
jiez is offline   Reply With Quote
Old   September 29, 2010, 02:46
maysmech's Avatar
maysmech is on a distinguished road
Originally Posted by jiez View Post
Hi, Foamers,
inlet
Thanks
I define it zeroGradient.
Also if you see same cases in tutorial files zeroGradient type is used for inlet.
maysmech is offline   Reply With Quote
Old   September 30, 2010, 12:23
Jie (Jay) Zhang
Thanks, maysam. I will try to figure it out.
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Sover setting with TUI junbbung FLUENT 0 August 20, 2009 01:43
LiftDrag utility from v12 to v141 cfdphil OpenFOAM Running, Solving & CFD 2 December 5, 2007 06:49
Ultra high temperature? bk Siemens 2 July 19, 2005 01:01
Warning 097- AB Siemens 6 November 15, 2004 05:41
