simple problem with internal faces Boundary condition |
May 19, 2015, 07:01 |
#21 |
Pruthvi
Rep Power: 12 |
//************ Problem solved ****************// If there are no non-conformal regions then OpenFOAM automatically considers the defaultFaces as an internal region
Hello everyone, Similar problem here. I have a structured + unstructured mesh from gmsh. There are a few internal faces which arise due to the hybrid mesh. Basically these are the intersections of different volumes. I'm not sure how to handle them. Importing the mesh to OpenFOAM defines them as follows defaultFaces { type patch; nFaces 284; startFace 562756; } How must I define these faces in the 0 dictionary? Here is the github link to the mesh https://github.com/pruthvi1991/gmsh/tree/master/pilot Thanks, Pruthvi. Last edited by pruthvi1991; May 19, 2015 at 14:43. Reason: Problem solved |
July 19, 2015, 18:38 |
#22 |
Dear Zahra,
I am sorry for not answering earlier. I have been absent from this forum for a long time due to job-search, finishing reports, etc... Nevertheless, for what it still might be worth: For your case you might consider a solver like rhoPorousSimpleFoam or porousSimpleFoam (depending if your case should be considered compressible or incompressible). Probably these are the quickest solution for your case. Although I do not know how far these solvers consider heat transport within the porous phase (if needed). Cheers, Bernhard |
June 8, 2019, 16:30 |
#23 | |
Rep Power: 11 |
But when you converting to OF then default patch is appearing in the polyMesh/boundary file. Do I have to delete that or I have to keep as it is. Will it appear in the 0 folder while using splitMeshRegions command. Mine is compound mesh generated in salome. Thanks |
May 26, 2020, 06:02 |
#24 | |
M.W.G.
Rep Power: 8 |
So, did you manage to solve your problem? I am going through the same exact situation now |
March 15, 2021, 22:53 |
solution for internal faces boundary condition
#25 |
Guanwen Luo
Rep Power: 5 |
Hi, I think the solution might be just simple. For the faces are actually interior fliuid, "zeroGradient" type of boundary is suitable.
April 21, 2022, 02:11 |
non-conformal meshes using anasys meshing
#26 | |
Emre
Rep Power: 6 |
Hello Mohammad, my problem is that when i shace faces in space claim so that there is only one face between two volumes i can not give two different edge sizings to create a nonconformal mesh so ansys automatically creates contact regions. These regions show up in boundary file after fluent3dmeshtofoam conversion. if anyone has overcome this problem i would be very happy to listen to the solution.
Thank you Quote:
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
Outflow boundary condition in cartesian grid SIMPLE velocity-pressure coupling | ghobold | Main CFD Forum | 9 | September 19, 2015 03:50 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
