calculate values for eps and k from Re or u?????
Old   July 16, 2010, 06:09
Default calculate values for eps and k from Re or u?????
Sebastian Bartscher
sbar is on a distinguished road
Hi Foamers!
I'm simulation an Flow around a cylinder to calculate the drag coefficent at different Reynold numbers. Im validating against thoeretical values.
My problem ist how to get the inlet conditions for k and epsilon. As inlet value i have just the Reynolds number. I can calculate the velocity from Re but is there an possibility to calculate k and epsilon from Re or the velocity? Or is there an possibility to tell Of to calculate the values like setting the inlet type to zeroGradient or calculated (i got errors when i tried).
thanks in advance!!
sbar is offline   Reply With Quote
Old   July 17, 2010, 10:10
David Boger
boger is on a distinguished road
Hi Sebastian,
You'll need to specify the values in some way, but this topic has been discussed before in the forum. Ryan had suggested this guide from the Fluent manual. I just checked, and that link is still active. Also see the follow-up post from Mark on that same thread.
David A. Boger
boger is offline   Reply With Quote
Old   July 20, 2010, 04:49
Sebastian Bartscher
Hi David,
Thanks a lot! that helped!
Old   July 20, 2010, 06:54
Sebastian Bartscher
ok now another question appeared
when the turbulence intensity is calculated by formula 6.2-1 of the fluent help:
I= 0.16(Re_Dh)^(-1/8)
I decreases at high Re numbers. This confuses me bit. doesn't high Reynoldnumbers mean "more turbulence" in general?
Is it because I is u'/u_avg and u avg increases "faster" at high Re?? (sorry for the sloppy description I'm quite unexperienced at cfd)
thanks a lot for the help!!
Old   August 15, 2010, 08:42
kiran Ambilpur
kiran is on a distinguished road
Send a message via Skype™ to kiran
hi sebastian,
its a general confusion for any one who is new to tubulence initially when i was new.
tubulence generally increases with increase in Re(at low Re numbers less than 10^5) number but when the flow Re is further increased(more than 10^6) then its effect on the flow decreases.
I means turbulent intensity Re_Dh is the Re number of flow.
generally I is very less percent for high compressible flows.
do not think of any u`/u avg terms to avoid your confusion
all the best
kiran is offline   Reply With Quote
Old   August 16, 2010, 05:10
Sebastian Bartscher
ok! thanks for the reply kiran!
Problem with a simple UDF to calculate cell-averaged particle values kmayank FLUENT 1 January 18, 2011 02:40
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 12:32
exact face values RubenG Main CFD Forum 0 June 22, 2009 12:09
Calculate CV values? JimiH FloEFD, FloWorks & FloTHERM 1 April 8, 2009 16:24
[OpenFOAM] How to calculate Values for veriables for point vishal ParaView 1 September 26, 2008 12:07
