Fluent Outflow boundary condition implemented in OF?
Old   March 19, 2010, 12:05
Default Fluent Outflow boundary condition implemented in OF?
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Hello FOAMers,
is there someone that knows if a BC similar to Fluent's outflow BC has already been implemented in OpenFOAM?
Fluent's guide says that:
Outflow boundary conditions in FLUENT are used to model flow exits where the details of the flow velocity and pressure are not known prior to solution of the flow problem. You do not define any conditions at outflow boundaries (unless you are modeling radiative heat transfer, a discrete phase of particles, or split mass flow): FLUENT extrapolates the required information from the interior.
Can be ok setting U, k, epsilon as inletOutlet, inletValue $innerField and p as zeroGradient both at the inlet and at the outlet? Since U is directed to the external of the domain at the outlet, the inletOutlet BC will use U as zeroGradient, in such a way that both U and p are not fixed in that boundary.
Thanks in advance for comments and suggestions!
maddalena
maddalena is offline   Reply With Quote
Old   March 19, 2010, 13:29
Leonardo Nettis
dinonettis is on a distinguished road
Hi maddalena!
if we consider the case of a flow over a wing within a square domain (boundaries: inlet, outlet, top, bottom) what I usually do, using the solver simpleFOAM, is to adopt the following settings:
inlet: U (k,epsilon) inletOutlet, p zeroGradient
outlet: U (k,epsilon) zeroGradient, p outletInlet
top, bottom: U (k,epsilon) freestream, p freestreamPressure.
if you want to avoid setting even the pressure at the outlet you can try simply changing the BC at the outlet from outletInlet to zeroGradient or freestreamPressure (actually the value is not needed in both). However I'm not sure the problem is well-posed in this way. Is the flow subsonic or supersonic??
let me know,
dino
dinonettis is offline   Reply With Quote
Old   March 22, 2010, 10:14
maddalena's Avatar
maddalena
Hi Dino,
The flow is subsonic, actually it is an incompressible flow. If I am right, freestream bc can be used on compressible flow only, thus that is not a possibility for me. That's why I chose inletOutlet everywhere.
As for my case, I cannot set the pressure at the outlet, since I do not know what its value is. I am trying to reproduce results from a Fluent simulation, and they used an outflow bc at the outlet, thus that is why I asked such a question.
Thanks for any suggestions you will give.
Cheers,
maddalena
Old   March 23, 2010, 04:09
Gijsbert Wierink
gwierink is on a distinguished road
Hi Maddalena,
Is it an idea to use zeroGradient also for p?
Regards, Gijs
gwierink is offline   Reply With Quote
Old   March 23, 2010, 05:40
maddalena's Avatar
maddalena
Well... this is what I did in the beginning:
setting U, k, epsilon as inletOutlet, inletValue $innerField and p as zeroGradient both at the inlet and at the outlet. Since U is directed to the external of the domain at the outlet, the inletOutlet BC will use U as zeroGradient, in such a way that both U and p are not fixed in that boundary
In that case, if the U inletValue is low (between 0.5 and 3 m/s), the solution is stable, but when raising U to 11 m/s, the solution explodes. However, I am worried the divergence is only a matter of iterations, even with low U value. As Dino noticed, I guess the problem is not well posed in this way...
Old   March 30, 2017, 11:34
Ali
alib022 is on a distinguished road
maddalena,
I know this is a really old post, but by any chance did you finally find the solutions to this? I'm stuck in the same problem now.
Thanks
alib022 is offline   Reply With Quote
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 13:26
outflow boundary condition for multiphase flow deepak FLUENT 1 June 21, 2007 09:23
Slip boundary condition what is inside normunds OpenFOAM Running, Solving & CFD 2 June 4, 2007 07:45
Outflow boundary condition in FLUENT Sri FLUENT 5 December 5, 2003 05:42
Fluent 5.0 boundary condition issue with RSM Flav Main CFD Forum 2 October 20, 1999 05:57
