Boundary Conditions for Internal compressible Flow
Like Tree3Likes
Old   October 3, 2013, 08:22
anshul bansal
anshul bansal is on a distinguished road
hi xisto
can u send your boundary condition file?
anshul bansal is offline   Reply With Quote
Old   October 3, 2013, 08:46
Carlos Xisto
xisto is on a distinguished road
Send a message via MSN to xisto
Check the previous posts, I think that I have put my 0 folder there..
Carlos
xisto is offline   Reply With Quote
Old   October 7, 2013, 10:10
anshul bansal
hi xisto
thnk for your reply
actually i am doing my work on c-d nozzle flow.
i take axisymmetry geometry of this.
actually i confuse about its boundary condition , here i attach my boundary file.... you just look into these and if found any problem please address me.
File Type: gz 0.tar.gz (971 Bytes, 38 views)
Old   February 12, 2015, 14:20
Matei Petrescu
mateiu2003k is on a distinguished road
Originally Posted by vwibaut View Post
Hi all
I would like to simulate a supersonic nozzle with and without shock. So I have the same boundary conditions of Xisto except for the pressure at the outlet. I use waveTransmissive to avoid the reflection of the wave.
Is it ok?
Other question: When I use waveTransmissive I have to choose a "linf". But how do I choose the value?
Have you found the answer to your questions? I want to do something similar and I am not getting a steady flow yet.
mateiu2003k is offline   Reply With Quote
Old   February 12, 2015, 14:43
Matei Petrescu
Hi Carlos,
I would like to see your thermophysicalProperties file from constant folder the simulation that worked for you in the past (rhoPisoFoam laminar case on a duct with a bump). I will try it along with your boundary conditions with sonicFoam solver available in OpenFoam 2.1.1 (version that I use -> this version no longer contains rhoPisoFoam solver). I would love to be able to test this in a nozzle geometry. My goal is to set up a pressure gradients across it and check the velocity profile.
Best,
Matei.
Old   August 20, 2015, 13:45
Default transonic BCs
  #26
Giles Richardson
ufocfd is on a distinguished road
Carlos, thanks very much for the BCs
Originally Posted by xisto View Post
These one are for the transonic case (works in the subsonic also).
For the supersonic you need to specify all variables at inlet (fixed values for temperature (static), pressure (static) and velocity). Extrapolate all variables from outlet (zero gradient).
ufocfd is offline   Reply With Quote
Old   May 17, 2016, 03:30
majid
majid pourdian is on a distinguished road
hi all
I want to simulate an internal supersonic flow with OF,but I have no idea fo my boundary condition,any one can help me?
majid pourdian is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Help needed with laminar couette flow boundary conditions bengt OpenFOAM Running, Solving & CFD 0 March 19, 2009 09:25
boundary conditions for boundary layer flow A. Al-zoubi CFX 0 November 3, 2007 08:11
compressible flow boundary conditions yangqing FLUENT 2 January 22, 2002 11:19
