Discretization settings Foam vs. Fluent
Old   July 20, 2009, 03:45
Default Discretization settings Foam vs. Fluent
wuppdupp is on a distinguished road
Dear Foamers,
I´m interested in the the performance of Fluent 6.3.26 in comparison with OpenFoam 1.5. I´m simulating a steady (simpleFoam solver in OF 1.5), isothermal, single phase problem using the realizable k-epsilon-model.
In order to get accurate results for my flow field, I chose the "second-order upwind" descritization scheme (for pressure, momentum, k, epsilon) in Fluent.
Here my Question:
How do I have to change the fvScheme-skript in OpenFoam to get the same settings as in Fluent?
I made different approaches using the "linearUpwind"-scheme. But it did´nt work, due to some errors. I´m not sure if "linearUpwind" is comparable to the "second-order upwind" scheme in Fluent.
I would appreciate any hints or help.
Thanks in advance.
wuppdupp
Among others I used this fvScheme script:
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linearUpwind;
grad(p) Gauss linearUpwind;
grad(U) Gauss linearUpwind;
divSchemes
default none;
div(phi,U) Gauss linearUpwind;
div(phi,k) Gauss linearUpwind;
div(phi,epsilon) Gauss linearUpwind;
div(phi,R) Gauss linearUpwind;
div(R) Gauss linearUpwind;
div(phi,nuTilda) Gauss linearUpwind;
div((nuEff*dev(grad(U).T()))) Gauss linearUpwind;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linearUpwind;
interpolate(U) linearUpwind;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
wuppdupp is offline   Reply With Quote
Old   July 21, 2009, 13:16
Paulo Alexandre Costa Rocha
paulo is on a distinguished road
Dear Wuppdupp,
Maybe the scheme that you need is QUICK. Search the forum for related posts. I personally use GammaV for velocity.
Best Regards,
Paulo Rocha
paulo is offline   Reply With Quote
Old   July 23, 2009, 09:39
Dear paulo,
I tried Quick and GammaV. (For the gradSchemes) Without success.
The only Schemes which work are linear an fourth.
Old   July 23, 2009, 14:10
Originally Posted by wuppdupp View Post
Dear paulo,
It makes sense, since QUICK and GammaV are divSchemes.
Try it.
Best Regards,
Paulo Rocha
Old   July 24, 2009, 05:38
Hi Paulo,
thank´s for your advice. It works fine. Is there any possibility to use higher order discretization schemes also for the gradSchemes and the interpolationSchemes?
I was quite confused because in the OF documentation is mentioned, that you can use other Schemes also for gradSchemes and interpolationSchemes.
Again, thank you very much!
Wuppdupp
Old   July 24, 2009, 11:08
Yes,
if you write something wrong in the schemes text, OpenFOAM will show you all the possibilities.
The books of Ferziger & Peric / Versteeg & Malalasekra have good explanation about many schemes.
Best Regards,
Paulo Rocha
Old   July 25, 2009, 03:35
Alberto Passalacqua
Hi Paulo,
Wuppdupp
Yes, it is possible to use higher order than second schemes for gradients. In particular, if you want to be sure you always have second order accuracy, you should change "Gauss linear" into "leastSquares". If you want a fourth order scheme you can use "fourth". All schemes can be used in a "limited" version (limited leastSquares, for example), which reduces the accuracy locally to keep the solution bounded.
For interpolation schemes the choice is wider (see tab 4.6 in the manual). The "cubic" is fourth order central scheme, and it exists in the limited version "limitedCubic".
Best,
Alberto Passalacqua
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 05:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
Fluent connection with simulink by TCP/IP Tanktruck Fluent UDF and Scheme Programming 1 June 28, 2009 13:56
FOAM licensed free to academic institutions Nabla Ltd. Main CFD Forum 0 November 18, 2002 11:24
