How to set up BCs for k epsilon model
Like Tree65Likes
Old   February 5, 2014, 09:33
Mehdi GHOZALI
Dadou is on a distinguished road
Yes I did type uniform in the input file.
for the free surface I kind figure it out.
I'm gonna try and find something about the kOmega model, do you have any link that I can start with ?
Thank you for your help
Dadou is offline   Reply With Quote
Old   February 5, 2014, 09:54
Mihai Pruna
mihaipruna is on a distinguished road
Here's some issues people have helped me with for internal flow:
http://www.cfd-online.com/Forums/ope...ty-driven.html
Mihai Pruna's Bio
mihaipruna is offline   Reply With Quote
Old   October 19, 2015, 17:25
Default value
  #43
Fei
Garfield is on a distinguished road
Originally Posted by nileshjrane View Post
Put this in "/0/k" file for inlet. 0.05 corresponds to 5%. The value is actual value of k that you can calculate from 5% Turb intensity. I am not sure whether it is significant or nor, but i think its better to use appropriate value nevertheless.
    inlet
        type            turbulentIntensityKineticEnergyInlet;
        intensity       0.05;
        value           uniform 60;
Hi, do you know how to calculate the initial value? here you make the initial value to be "uniform 60"
Garfield is offline   Reply With Quote
Old   October 26, 2015, 09:58
Vineet Bhola
vineet_bhola is on a distinguished road
If you know approximate values of average velocity OR some Initial guess/rough calculations, you can use the formulae below for k and Epsilon.
http://www.cfd-online.com/Wiki/Turbu...ary_conditions
Hope that helps.
Vineet
vineet_bhola is offline   Reply With Quote
Old   October 26, 2015, 10:23
Smile Thanks a lot
  #45
Fei
Thanks a lot, that helps!
boundary conditions, eps, epsilon, initiallisation, turbulence
How to set an equilibrium-Air model jorge sancho CFX 4 August 24, 2015 07:32
radial fan model bc's seza FLUENT 2 December 27, 2013 04:52
Porous model jack FLUENT 2 August 11, 2008 05:16
Help: Set Up model in CFD with time Ranie Go Main CFD Forum 5 October 7, 2003 06:12
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
