How to set up BCs for k epsilon model
Like Tree65Likes
Old   May 30, 2011, 15:32
maysmech's Avatar
maysmech is on a distinguished road
Hi Juan, I didn't face your problem before.
Hi Eren, I have doubt about using free stream for both U and P. I haven't used this boundary too.
Try using fixed value for U and zeroGradient for P and nut if possible in your case. i suggest to use settings same as tutorial settings.
Any other suggestions for these two problems will be appreciated.
maysmech is offline   Reply With Quote
Old   May 30, 2011, 15:35
maysmech's Avatar
Other possible for convergence problem of simpleFoam is running an unsteady case with this steady solver.
i had this experience. Switching to pisoFoam solved my problem.
Old   June 22, 2011, 09:27
The True
Eren10 is on a distinguished road
How important is the initial values for k and epsilon. I know that it doesn't require exact values but what is maximum variation ? Or is it enough if it converges well with the right yPlus values.
Eren10 is offline   Reply With Quote
Old   June 22, 2011, 10:05
maysmech's Avatar
Initial values are not important and your solution is independent on them but, you should set them exactly in boundaries.
SailorLiu likes this.
Old   June 22, 2011, 10:21
The True
This sounds as a contradiction !
Old   June 22, 2011, 10:48
maysmech's Avatar
I don't see any contradiction. what is set in 0 folder is not initial condition only. you should set also boundary condition in this folder. if you see e.g case/0/U what is written after "Internal field" is initial value and after "Boundary field" is boundary condition. boundary condition effects solution in next iterations but initial value doesn't.
vineet_bhola likes this.
Old   June 22, 2011, 12:33
The True
Thank you ! I overlooked that. I have set that correct and now I have almost the same Cl. Only Cd is almost 2 times higher , y+ lies between 14-40 , average 29.5 . This is also not too bad.
Do you know what the cause of much higher Cd is ?
Old   June 21, 2012, 21:41
Mihai Pruna
mihaipruna is on a distinguished road
This seems to have worked for me. Internal flow,compressible:
SDuctOutlet
type inletOutlet;
inletValue uniform 200;
value uniform 200;
SDuctInlet
type compressible::turbulentMixingLengthDissipationRate Inlet;
mixingLength 0.005;
value uniform 200;
vol1face4
type compressible::epsilonWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
however...what should I do for freestream conditions parallel to the flow?
I have thins and I'm sure it's wrong
rightZmax
{type compressible::turbulentMixingLengthDissipationRate Inlet;
mixingLength 0.005;
value uniform 200;
mihaipruna is offline   Reply With Quote
Old   January 15, 2013, 11:08
Malik
malaboss is on a distinguished road
Originally Posted by wolle1982 View Post
inlet:
U: fixed value
p: zero gradient
k/eps/omega: value
outlet:
U: zero ngradient
p: fixed value (0)
k/eps/omega: zero gradient
walls:
U: fixed value
p: zero gradient
I tried to use those boundary conditions for my model.
I use a k epsilon turbulence model, and the simpleFoam (steady) solver.
At the inlet I fixed the value 1.5 for k since my flow's velocity is 10m/s et my turbulent intensity is 10%.
When I look at the k field and the epsilon field, they seem to be far from true as you can see in the picture I enclosed.
I think that this problem is related to the boundary condition at the outlet.
Do you have an idea about what could be the problem ?
Thx for all !
malaboss is offline   Reply With Quote
Old   January 31, 2013, 13:05
Default Similar Problem
  #30
Suranga Dharmarathne
sdharmar is on a distinguished road
I have a similar type of problem too. Why can not we set k=0 at wall boundaries. According to theory all the velocity fluctuations are zero at the wall boundaries hence k should be 0.
I gave this BC in one of my simulations and couldn't see k=0 at the wall in post processed results. Have attached the figure.
Please help me to figure this out.
sdharmar is offline   Reply With Quote
Old   February 1, 2013, 03:58
Malik
I just forgot to tell that I found what was my problem : I has inverted my inlet boundary conditions with my outlet boundary conditions.
However, for your case, it seems like you have fixed a k value at the inlet and put zero gradient at the outlet.
Maybe you should try to see if your velocity boundary conditions are OK.
For your second question : there is no reason why k would be zero at the wall because the boundary condition is zeroGradient.
You use this boundary condition when you work with a wall function (see simpleFoam/pitzDaily tutorial for example). And when you don't use wall function, you can put a value near 0 on the wall. For example you can see the lowRekEpsilon model LaunderSharma tutorials.
It does not answer your question but it shows that these boundary conditions are classical.
The reason why we use zero gradient when we have a wall function was explained in another thread here : what i understood was that on the first cell the wall function creates a profile of k, espilon, U ... You do not see that because on your simulation there is only one value in one cell. But you should not actually worry about it.
This is all I know on the subject and there must be a lot of things I do not understand, so be careful with what i said !
Old   February 1, 2013, 13:38
Default BC for k
  #32
Thanks for your reply.
It seems that I have not expressed my question clearly in the previous post. I am very sorry about that.
The boundary conditions are exactly same for U and p as in your post on Jan 15 2013.
For k and epsilon I put
fixedValue condition at the inlet
zeroGradient condition at the outlet
And at the walls
for k , type fixedValue;
value uniform 0;
and for epsilon,
type zeroGradient;
for these conditions I got above diagram for k. You can see that I have explicitly set k=0 at the wall.
That is the problem I have. Why doesn't the diagram show k=0. Is it a wrong BC for the k-epsilon model.
Please give me a clue. Once again thank you in advance.
Old   February 3, 2013, 09:35
Malik
Could you tell me if you use wall function ?
Maybe you should try to avoid using wall function for your case as you want to fix a value for k (which means not setting the BC nutWallFunction for nut).
Tell me if it helped.
Old   August 19, 2013, 05:48
Vishal
inf.vish is on a distinguished road
Hi Julian,
Can you please share your files for the elbow tutorial if you still have them?
I am also trying to simulate the elbow tutorial with turbulence but not able to get turbulence and everything just looks laminar.
inf.vish is offline   Reply With Quote
Old   August 20, 2013, 14:42
Default setting of omega BC"s
  #35
sonu
yash.aesi is on a distinguished road
helo
I am trying to set up a case using rhopimplefoam solver and the kOmegaSST turbulance model model but I have difficulties defining the boundary conditions for omega.
in my case i have inlet , axis , upperwall, outlet so hw to define BC's for that ?
yash.aesi is offline   Reply With Quote
Old   August 21, 2013, 07:03
immortality's Avatar
Ehsan
immortality is on a distinguished road
what Eren?you have set both p and U in inlet by values and both zeroGradient in outlet?
that's wrong obviously.
you should set p be value in outlet and whether p or U be value in inlet and the other be zeroGradient in inlet. k and epsilon seems be correct.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   February 5, 2014, 08:55
Default Boundary Conditions
  #37
Mehdi GHOZALI
Dadou is on a distinguished road
Hello Everyone,
I see that you are quit familiar with all the BCs settings.
I have a question for you all about the settings of U,P,k,epsilon and nut. I am trying to model a 3D free surface flow (flow goes in [inlet] and the same flow goes out [outlet]) and I'm having a hard time setting boundary conditions for allthe U,P... .
I tried to follow some instructions suggested in this threads but I didn't really find what I need. So (as you can see in the pictures attached) I need to have in the Inlet a flow condition and outlet flow condition too. For the walls (k, Epsilon and nut) I used respectively :
- kqRWallFunction uniforme 1;
- epsilonWallFunction uniform 200;
- nutkWallFunction uniform 0;
(I copied the values from a tutorial)
I am using a simpleFoam solver with RASModel ---> kEpsilon
Can someone help me with th BCs it's the first time that I have to do the settings so I'm a little bit lost
Thank you
Dadou
Dadou is offline   Reply With Quote
Old   February 5, 2014, 09:10
Mihai Pruna
Dadou: I can't see the attachments.
Mihai Pruna's Bio
Old   February 5, 2014, 09:16
Mehdi GHOZALI
I Apparently it didn't work.
And Now ?
File Type: jpg Screenshot from 2014-02-04 13_44_02.jpg (45.3 KB, 125 views)
File Type: jpg Screenshot from 2014-02-04 14_17_22.jpg (81.5 KB, 85 views)
Old   February 5, 2014, 09:23
Mihai Pruna
three things:
did you actually type "uniforme" in the input file?
try to set your free surface like freestream in the motorbike tutorial.
if no typos in the file, I would suggest a K-omega model, look into the forums for definitions and initial conditions settings.
Mihai Pruna's Bio
boundary conditions, eps, epsilon, initiallisation, turbulence
How to set an equilibrium-Air model jorge sancho CFX 4 August 24, 2015 07:32
radial fan model bc's seza FLUENT 2 December 27, 2013 04:52
Porous model jack FLUENT 2 August 11, 2008 05:16
Help: Set Up model in CFD with time Ranie Go Main CFD Forum 5 October 7, 2003 06:12
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
