How to set a time varying velocity field as a BC? |
March 16, 2009, 08:10 |
Nabil
Rep Power: 17 |
I'm trying to simulate blood flow in a arterie and i want to set the pulsating velocity as a boundary condition at the inlet. As i'm new to OpenFOAM and my C++ knowledge is limited at best, i was hoping that somebody here could point me to the right direction. I was thinking of using the timevaryinguniformfixedvalue, and read from a file, like "inlet.dat" or smth like that. however I'm not sure on how to make it read a field for each timestep, instead of a vector, so any help in that department is really appreciated. Thanks in advance. |
March 16, 2009, 08:28 |
I think this might help you: http://openfoamwiki.net/index.php/OscillatingFixedValue Regards, Jose Santos |
March 16, 2009, 09:39 |
#3 | |
Nabil
Rep Power: 17 |
March 17, 2009, 11:13 |
Chris
Rep Power: 17 |
Hi Mikro,
I am also calculating blood flow in arterie. I wonder which viscosity model do you use? Regards, Chris |
March 17, 2009, 13:57 |
Dragos
Rep Power: 20 |
If you want the timeVaringUniformFixedValue, then check this thread:
http://www.cfd-online.com/Forums/ope...tml#post190753 and for the file format: http://www.cfd-online.com/Forums/ope...tml#post190756 Dragos |
March 19, 2009, 05:38 |
Nabil
Rep Power: 17 |
I plan to use several and compare the diffrences, however i'm setting upp a newotonian case first, and right now the inlett velocity is giving me a pain in the ***...
Time Varying Equations | Boris Besancon | FLUENT | 1 | January 14, 2010 13:01 |
Varying Velocity | mrj301988 | OpenFOAM Pre-Processing | 0 | January 21, 2009 09:43 |
time varying inlet velocity | Zhe Liu | CFX | 0 | July 31, 2008 07:56 |
sinsoudial time varying BC | cfd-student | CFX | 4 | May 1, 2008 20:06 |
Time Varying BC | A.S. | Siemens | 1 | January 31, 2005 07:37 |
