Amalia Apalategui
Rep Power: 17 ![]() |
Hi!
I am a new user. I have a complex geometry and I want to know if the only way to describe it is editing the blockMeshDict file. Thanks a lot Amalia |
Mattijs Janssens
Rep Power: 26 ![]() |
There is an option -blockTopology to blockMesh which will dump out the block points. You can visualize the resulting .obj files with e.g. javaview or run objToVTK and use paraview. The node numbering in either program will be the same as the blockMesh block points. I find this is quite useful for multiblock meshes.
Eugene de Villiers
Rep Power: 21 ![]() |
You can also use 3rd party meshers and convert the results to foam format using the converters found in:
OpenFOAM-1.1/applications/utilities/mesh/conversion/ There are quite a lot of formats to choose from. |
Amalia Apalategui
Hi Mattijs!
Thanks for your answer... where can I find some docu about that? Where can I find blockTopology? How should I use it? Thanks Amalia |
Mattijs Janssens
Sorry, no docu. It is a command-line option and probably not yet in FoamX. Do
blockMesh - to find out any command-line options. |
Amalia Apalategui
Hi Mattijs!
I have created the .obj file with blockMesh -blockTopology, then I have created the VTK file with objtoVTK and I have a problem because I can not visualize the VTK file with paraview. I get the message "Could not find an appropiate reader for this file. Would you like to manually select the reader for this vile"? I have trid with some of the list, but it does not seem ok... Thanks Amalia |
From mesh to geometry | laura | CFX | 3 | September 12, 2008 11:33 |
What does mesh geometry mean? | anthro | FLUENT | 1 | January 21, 2007 13:41 |
how to get the whole geometry mesh | iceraining01 | Main CFD Forum | 6 | September 24, 2005 11:42 |
mesh geometry and stl? | jemteo | CFX | 0 | July 11, 2004 22:35 |
How to mesh this geometry? | Sandy | FLUENT | 0 | September 26, 2003 18:28 |
