Mapping fields
Old   September 14, 2005, 17:07
Default Hi, For two cases with iden
Pei-Ying Hsieh
hsieh is on a distinguished road
For two cases with identical geometry, is it possible to map only certain data, say gamma field from source to target and set U and P zero in target? The following is the reason:
If I finish solving one case, and I would like to use the same gamma field for a second run with different starting inlet velocity.
It will be appreciated if you can point a direction to me.
pei
hsieh is offline   Reply With Quote
Old   September 14, 2005, 17:59
Default I don't if you can specify the
Duderino
duderino is on a distinguished road
I don't if you can specify the data you want to map.
But you can do first the mapping of gamma and than reedit or overwrite your P and U. This is maybe not the most elegant solution, but it will do the job.
jens
duderino is offline   Reply With Quote
Old   September 14, 2005, 18:17
Default Hi, Jens, Could you explain
Pei-Ying Hsieh
Hi, Jens,
Could you explain your approach? If I do mapping, then all fields (gamma, U, and p) will be mapped to the target case at the same time step. How do I re-edit p and U to zero? (Now that I think about it, I can write a small C code to read U and p in, set everything to 0 and then write them out.)
pei
Old   September 14, 2005, 20:56
Default Hi, Jens, After more though
Pei-Ying Hsieh
Hi, Jens,
After more thought, I think your idea is pretty good. What I ended up doing is:
1. initialzied the new case to zero for p/U/gamma.
2. copy gamm from source case to the target case at time 0 (this will replace the original gamma file).
3. added BCs at the end of the gamma file.
In this case, I did not even have to do any mapping.
pei
Mapping fields from fvMesh to tetPolyMesh hannes OpenFOAM Running, Solving & CFD 2 August 28, 2008 06:42
MultiDirRefinement class Bug on mapping fields zurdo OpenFOAM Bugs 12 December 17, 2007 05:54
Mapping volsurface symmTensor fields after a topological change jcmasters OpenFOAM Bugs 1 September 4, 2007 14:48
3D to 2D mapping Ramesh Main CFD Forum 0 April 9, 2007 02:07
Error after mapping fields alberto OpenFOAM Pre-Processing 0 November 2, 2006 19:47
