Math form expressed in OpenFoam
Old   November 10, 2005, 04:34
Default volVectorField A = (a, b, c)
VVqf
vvqf is on a distinguished road
volVectorField U = (u, v, w)
a*Ñu + b*Ñv + c*Ñw
How to describe this expression in OpenFoam?
I express it as A*grad(U), grad(U) is then a tensor. Is that right?
I tried many ways to denote it in the codes, well, each time i got errors like "no match ..."
ps:
in OpenFoam,(U . Ñ)U is expressed as div(phi,U), phi = rho*U?
vvqf is offline   Reply With Quote
Old   November 10, 2005, 08:26
Default original form: a¶xu + b¶
VVqf
original form:
axu + b<font size="-1">xv + cxw</font>
ayu + b<font size="-1">yv + cyw</font>
azu + b<font size="-1">zv + czw</font>
Thanks a lot.
Old   November 10, 2005, 08:35
Default http://foam.sourceforge.net/do
Eugene de Villiers
eugene is on a distinguished road
http://foam.sourceforge.net/doc/Guid...mmersGuide.pdf
Check section one for a general overview of OpenFOAM tensor algebra and notation. Very useful document IMO.
eugene is offline   Reply With Quote
Old   November 10, 2005, 09:50
Default Thank you so much. I mixed
VVqf
Thank you so much.
I mixed * and &.
and operator calculation order is the written/appearing order, *, /, ect, do not have precedence to +, -.
Old   November 10, 2005, 10:38
Default Yes - the one thing you can't
Gavin Tabor
grtabor is on a distinguished road
Yes - the one thing you can't redefine (or one of the things you can't redefine) in c++ is the order of precedence for the various binary operators. Its probably worth adding lots of brackets into your expressions to compensate for this.
Gavin
grtabor is offline   Reply With Quote
Can OpenFoam be made faster or which Math kernel library is used jens_klostermann OpenFOAM 0 February 4, 2008 09:37
Has anyone tried a delta form of pressure equation pressurecorrection equation with OpenFOAM sek OpenFOAM Running, Solving & CFD 2 July 24, 2007 08:53
Math notation in OpenFoam a gradb gradb a vvqf OpenFOAM 0 November 24, 2005 08:17
Generalized Math. Form of Turbulence Nomad Main CFD Forum 38 March 22, 2004 10:03
MATH * MATH + MATH - MATH Mehdi BEN ELHADJ Main CFD Forum 2 October 9, 2000 17:02
