DivphiU expression in incompressible solvers
Old   November 15, 2005, 11:26
Default In OpenFoam, the term (U . Ñ)U
VVqf
vvqf is on a distinguished road
In OpenFoam, the term (U . Ñ)U in N-S equation is expressed as div(phi,U),where phi is surfaceScalarField, and phi = linearInterpolate(Uo) & mesh.Sf(). I don't understand this.
I think it can also expressed as U . ÑU, (inner product),which in OpenFoam is U & fvc::grad(U)).(why not in this way?)
in OpenFoam, div(phi,U) is said to mean Ñ . (UU), and flux f=U
see User Guide U-110
createPhi.H
#ifndef createPhi_H
#define createPhi_H
Info<< "Reading/calculating face flux field phi\n" << endl;
surfaceScalarField phi
IOobject
"phi",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT,
IOobject::AUTO_WRITE
linearInterpolate(U) & mesh.Sf()
#endif
vvqf is offline   Reply With Quote
Old   November 15, 2005, 12:29
Default U & fvc::grad(U)) wouldn't be
Gavin Tabor
grtabor is on a distinguished road
U & fvc::grad(U)) wouldn't be conservative. The FVM for all transport equations is to discretise
div(phi q)
where q is the unknown variable - could be k, epsilon, temperature, whatever... or in this case any of the components of the velocity. Applying Gauss theorem to the cell converts this into a sum of the fluxes through the faces of the cell, which is what ensures conservation. Of course you do need to get the flux from somewhere, which is what the interpolation is there for.
It is a bit difficult to grasp at first, but we do need to make a distinction between velocity and flux. This is standard practice in FV CFD codes. not just FOAM. Have a look at a textbook in the area (my favourite is Versteeg + Malalasekera)
Gavin
grtabor is offline   Reply With Quote
Old   November 23, 2005, 06:50
Default if the term (U奄)U could be n
VVqf
if the term (U奄)U could be non-conservative, mathematically, put the physical meaning aside, is it ok to use U & fvc::grad(U))?
or will it cause a inconvergent solution when using the solver, like the residual very large, even "nan" ?
Old   November 23, 2005, 10:59
Default You can do whatever you like,
Hrvoje Jasak
You can do whatever you like, but the
U & fvc::grad(U)
will be explicit, with the appropriate effects on stability, convergence etc. I would go for
div(U U) - U div(U)
which is the same as U & grad(U) but can be made implicit in both terms (or course, you need to write this in the FOAM language. Mind the fluxes, etc.) :-)
Have fun,
Hrv
Hrvoje Jasak
Old   November 24, 2005, 08:09
Default it is really nice of you to an
VVqf
it is really nice of you to anwer my question.
Yes, it is of some fun, but as well as *&^%#@
I would not think of expressing the term in div()terms, and also difficult for me to transform in this way.
I want to ask further:
2 vectors : a, b
Could you give me suggestion what is the proper way to express
<a,Ñb> + <b,Ña> ?
Thanks again.
Old   November 24, 2005, 08:19
Default sorry. it should be +
VVqf
sorry. it should be
<a,Ñb> + <Ñb,a>
Exactly, I wanna solve U
<u',Ñu> + <Ñu,u'>
Old   November 25, 2005, 09:46
Default at first, I thought your trans
VVqf
at first, I thought your transformation
U & fvc::grad(U) = div(U U) - U div(U)
is wrong. later i think there is a mistake in
Programmer's Guide, page P-28
equation (2.5)
should it be : dTij/dxj ?
dT11/dx1 + dT12/dx2 + dT13/dx3
dT21/dx1 + dT22/dx2 + dT23/dx3
dT31/dx1 + dT32/dx2 + dT33/dx3
Old   November 25, 2005, 10:14
Default if so, then i can come to the
VVqf
if so, then i can come to the conclusion :
(U'•Ñ)U = Ñ•(U U') = U'•(ÑU)
Then,
(U'奄)U = fvm::div(phi, U')
is that right?
http://www.cfd-online.com/OpenFOAM_D...tml?1132700141
Pressure force calculation in incompressible solvers philippose OpenFOAM Running, Solving & CFD 10 December 7, 2019 05:51
Incompressible vs compressible solvers James Main CFD Forum 5 January 19, 2009 06:15
SonicFoam divphiU dimi OpenFOAM Running, Solving & CFD 3 June 25, 2007 06:47
NS-incompressible and compressible flow solvers ag Main CFD Forum 2 September 27, 2005 07:18
CEL expression Henry CFX 2 August 7, 2004 13:16
