RunFoamXHB problem
Old   December 1, 2005, 04:32
Default Can anybody help me with this?
Charles Crosby
crosby is on a distinguished road
Can anybody help me with this? I can't get FoamX started because runFoamXHB is unhappy about something. The OS is Fedora Core 4 on AMD64, and I've installed and compiled from source for 64-bit. I suspect that the problem is being caused by some network service that Fedora is blocking, but I haven't been able to find it. Any suggestions? Error message is as given below:
/home/charles/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: line 131: 14338 Segmentation fault FoamXHostBrowser -ORBNamingAddr $myIOP
runFoamXHB : cleanup
runFoamXHB: Killing name server nsd(pid 14330).
/home/charles/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: line 66: 14330 Killed nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null
crosby is offline   Reply With Quote
Old   December 1, 2005, 05:30
Default Have you tried changing the po
Mattijs Janssens
mattijs is on a distinguished road
Have you tried changing the port? In $FOAMX_CONFIG/FoamXClient.cfg
Can run 64bit under Suse10 fine on amd64 so cannot be architecture issue.
mattijs is offline   Reply With Quote
Old   December 1, 2005, 05:52
Default Thanks for that piece of advic
Charles Crosby
Thanks for that piece of advice Mattijs. I tried setting the port explicitly to 1234, but that didn't seem to make any difference. Then I switched the 64-bit flag off and it did work. I think now that I have a mixup of 32-bit and 64-bit libraries and executables (paraFoam wasn't happy either), so now I am trying a wcleanall and rebuild in pure 32-bit mode.
VOF diffuse problem on two fluids problem Fang Jin FLUENT 5 February 17, 2011 06:38
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 10:37
Problem in cavity flow problem saad Main CFD Forum 4 November 1, 2007 08:45
A new RunFoamXHB problem canbt start FoamX alondono OpenFOAM Pre-Processing 0 January 26, 2007 23:14
problem in solving "wave generation" problem san FLUENT 2 April 4, 2006 00:37
