FoamX does not eat numbers
Old   February 16, 2005, 06:06
Default Hello, whenever I would like
Martin Lorenz (Lorenz)
whenever I would like to change any number within FoamX (for example a boundary value), it complains with a FoamXException:
"Number 123.45 not of correct type!"
Even if i don't change a value, but simply move the cursor to the field and press Tab/Enter, I get the same message!
Any hints? I have OpenFoam 1.0.2/Linux and use the Java SDK as downloaded from the OpenFoam site.
Old   February 16, 2005, 06:29
Default I think this is somewhere on
Mattijs Janssens (Mattijs)
I think this is somewhere on this site and has to do with the language Java expects numbers in (LANG environment setting). You should be able to find it using the search facility.
Mattijs
Old   March 23, 2005, 19:00
Default i have the same problem... i'm
Guillermo Follert Emhart
gfollert is on a distinguished road
i have the same problem... i'm trying but it's impossible.
gfollert is offline   Reply With Quote
Old   March 23, 2005, 19:30
Default Well i had the same problem He
atzaru
Well i had the same problem Here is how to solve:
you need to edit your .bash file in ~/OpenFOAM/OpenFOAM-1.0/.OpenFOAM-1.0/bashrc
just add at the very begining
export LANG=en_EN
Hope this work
Atzaru
Old   March 28, 2005, 16:33
Default at least for me it doesn't wor
at least for me it doesn't work. I'm running on mandrake 10.1 and OpenFOAM 1.1, and it's impossible to modify any value on the dictionaries.
Old   March 29, 2005, 01:53
Default well, i have re-installed linu
well, i have re-installed linux (and OpenFOAM, obviously), but in english (i've previously installed linux in my "native" language:spanish), and everything seems to be OK...
Old   April 12, 2005, 16:56
Default i tried in another pc with FC3
i tried in another pc with FC3 and it works fine
Old   August 31, 2005, 13:32
Default I had the same problem here on
laika
I had the same problem here on SuSe9.3 with Dutch language settings. Setting the LANG variable to en_EN prior to starting FoamX solved the problem.
cheers,
Laika,
still orbiting
Old   January 21, 2006, 17:06
Default Thank you it worked for me to.
newbee
Thank you it worked for me to. Im on a inspiron 1300 laptop using ubuntu 5.10.
Old   January 21, 2006, 18:03
newbee
Dimensionless Numbers Kees Main CFD Forum 1 April 2, 2008 10:15
Dimensionless numbers kuba FLUENT 2 September 6, 2007 05:48
Cell Numbers furkan Siemens 3 November 24, 2005 04:06
Rayleigh numbers?? ocy FLUENT 4 February 28, 2005 03:19
Caracteristic numbers in CFD Khalel A. Main CFD Forum 1 April 26, 1999 13:36
