July 11, 2006, 14:29 |
In OpenFOAM 1.3, if you notice
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
In OpenFOAM 1.3, if you notice the following warnings when you start FoamX and double-click on your hostname, it is possibly because of a re-organization[1].
--> FOAM Warning : From function FoamX::IPropertiesImpl::IPropertiesImpl(bool readOnly) in file IPropertiesImpl.C at line 375 User specified root directory "$FOAM_RUN/tutorials/icoTopoFoam" ("/home/cfd/OpenFOAM/cfd-1.3/run/tutorials/icoTopoFoam") not found. Removing from root directories list. --> FOAM Warning : From function FoamX::IPropertiesImpl::IPropertiesImpl(bool readOnly) in file IPropertiesImpl.C at line 375 User specified root directory "$FOAM_RUN/tutorials/icoFoamAutoMotion" ("/home/cfd/OpenFOAM/cfd-1.3/run/tutorials/icoFoamAutoMotion") not found. Removing from root directories list. [1] http://www.cfd-online.com/OpenFOAM_D...es/1/2241.html If you wish to work around this annoying yet harmless warning, all you need to do is edit ~/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/controlDict and comment out these two lines by prefixing them with //: "$FOAM_RUN/tutorials/icoTopoFoam" "$FOAM_RUN/tutorials/icoFoamAutoMotion" |
About FoamX | ivanyao | OpenFOAM Installation | 2 | September 21, 2008 22:24 |
RhoSimpleFoam FoamX | spv24 | OpenFOAM Running, Solving & CFD | 1 | July 21, 2008 11:29 |
FoamX | ianz8802 | OpenFOAM Installation | 2 | March 9, 2007 00:45 |
Run FoamX | ghazi | OpenFOAM Pre-Processing | 7 | July 9, 2006 15:48 |
converged solution or correct solution | SAM | FLUENT | 1 | October 12, 2004 16:38 |
