ReconstructPar error
Old   November 28, 2005, 12:29
Default Hi, I am having some problem
Radu Mustata
r2d2 is on a distinguished road
I am having some problem with the reconstructPar utiliy which worked fine until now and I do not seem to be able to locate it.
The error that I am having is:
Time = 0
Reconstructing FV fields
Reconstructing volScalarFields
p
terminate called after throwing an instance of 'std::bad_cast'
what(): St8bad_cast
Aborted
...(this is decomposePar <my> and then reconstructPar <my>)
Thanks,
Radu
r2d2 is offline   Reply With Quote
Old   November 29, 2005, 04:30
Default I face the same problem, with
Maka Mohu
maka is on a distinguished road
I face the same problem, with the standard channel tutorial case. But it works fine with cavity case.
maka is offline   Reply With Quote
Old   November 29, 2005, 06:43
Default Hi Maka, can you report thi
Mattijs Janssens
mattijs is on a distinguished road
Hi Maka,
can you report this as a bug?
mattijs is offline   Reply With Quote
Old   November 29, 2005, 08:10
Default Hi Mattijs, I did. Thanks f
Maka Mohu
Hi Mattijs,
I did. Thanks for your reply.
/Maka
Old   November 29, 2005, 10:49
Default Bug solved in: http://www.c
Maka Mohu
Bug solved in:
http://www.cfd-online.com/OpenFOAM_D...tml?1133275691
/Maka.
Old   November 29, 2005, 10:52
Default I already saw it. Frogot to ac
Radu Mustata
I already saw it. Frogot to acknowledge it, though. Sorry about that.
Radu
Old   September 12, 2006, 10:23
Default I cannot access the link, and
Daniele Panara
panara is on a distinguished road
I cannot access the link, and I would like to know how to solve this bug, can anybody help?
Daniele
panara is offline   Reply With Quote
Old   September 12, 2006, 10:37
Default donīt have that problem anymor
Radu Mustata
donīt have that problem anymore, and cannot even remember what was is about. I repeat, everything works fine for me right now.
Radu
Bug in reconstructPar david OpenFOAM Bugs 10 May 26, 2009 13:11
ReconstructPar kupiainen OpenFOAM Post-Processing 12 April 21, 2009 02:47
[mesh manipulation] Error with reconstructPar skabilan OpenFOAM Meshing & Mesh Conversion 3 June 10, 2008 19:34
ReconstructPar maka OpenFOAM Bugs 6 August 22, 2007 05:23
ReconstructPar channelOodles error maka OpenFOAM Post-Processing 6 September 13, 2006 17:16
