OpenFOAM and Salome
Old   September 25, 2006, 03:58
Default Hi, I have read few days ago
Frédéric
fred is on a distinguished road
I have read few days ago some posts on salome, as a preprocessor (geometry, mesh generation).
Does Salome exports geometry, and/or mesh in one of OpenFOAM formats ?
Best regards,
Frédéric
fred is offline   Reply With Quote
Old   September 25, 2006, 05:03
Default Can Salome output unv files? I
Mattijs Janssens
mattijs is on a distinguished road
Can Salome output unv files? I read something about a unvToFoam script posted here.
mattijs is offline   Reply With Quote
Old   September 25, 2006, 06:57
Default Mattijs, Salome can write (I-D
sergei shulepov
sergei is on a distinguished road
Mattijs, Salome can write (I-DEAS) .unv files. We have tested some simple geometries (created whithin Salome, so) and meshed those. STAR can import those meshes including shells whithout problems. Did not try it yet in OpenFOAM (have it on suse 10.0, but cannot make salome running on it, probably have to try a bit harder)
sergei is offline   Reply With Quote
Old   September 25, 2006, 07:27
Default Sergei, I was also playing
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Sergei,
I was also playing around with Salome and had no problem imported unv files that I've converted from Foam with the foamMeshToUnv.tar.gz conversion utility.
If, however, I wish to create a group (for tagging boundary conditions), I can only select nodes or elements, but not the faces of elements (which I would require for Foam). Is this possible in Salome?
Thanks,
/mark
olesen is offline   Reply With Quote
Old   September 25, 2006, 12:10
Default Mark, I have to honest, we di
sergei shulepov
Mark,
I have to honest, we didn't put much effort into Salome yet (because I could run it on SuSE only from version 10.1).
Basically, what we are doing, importing "raw" meshes (from different packages, even from ICEM) into STAR-CD, and then finishing the model in it.
OpenFOAM (we are using it only for some special cases, because of speed) has excelent convertor for it, so why bother.
Anyway, I am going to look in more details at Salome, and will come back with answer to your question
Old   September 25, 2006, 12:37
Default I played a little bit with SAL
Billy
billy is on a distinguished road
I played a little bit with SALOME and I it exports UNV (I-deas). In this thread you can see I attempted to build a converter. It has several limitations because UNV format is quite extense.
http://www.cfd-online.com/OpenFOAM_D...tml?1158103068
If someone could test and improve the code, it would be great.
billy is offline   Reply With Quote
Old   September 25, 2006, 21:36
Default Hi, The developer of CAELin
Pei-Ying Hsieh
hsieh is on a distinguished road
The developer of CAELinux LiveDVD developed a python code to convert unv file to OpenFOAM (I guess it is OpenFOAM 1.2) format. I have not tried this python code myself yet.
I was not able to install Salmoe v3.2.1 on a SuSE 10.1 64 bit OS. It was pretty easy to install Salome v3.2.1 on Mandriva 2006 (32 bit). But, the easiest is to use the CAELinux LiveDVD. I guess that the BC info can be obtained through using "groups" in unv.
pei
hsieh is offline   Reply With Quote
MRFSimpleFoam amp Salome Meca tommie OpenFOAM Running, Solving & CFD 5 November 5, 2014 03:54
[Salome] Salome giordy OpenFOAM Meshing & Mesh Conversion 3 September 5, 2008 08:36
OpenFOAM results in SALOME kar OpenFOAM Post-Processing 1 January 31, 2008 14:15
Salome creating patches within faces hoogland OpenFOAM Pre-Processing 1 November 8, 2007 02:51
[Salome] Salome 321 and UNV micpage18 OpenFOAM Meshing & Mesh Conversion 28 September 12, 2006 20:17
