Inlet slot for rooms
Old   September 20, 2006, 02:58
Default Hi, at first sorry for my b
myting
at first sorry for my bad english...
However, I want to use OpenFOAM for simulation. I am engineer for HVAC and I am to interesset in simulation for airflows in building rooms but my experiment crashed in OpenFOAM everytime :-(
I make a room with one block and every side is a wall function. Furthermore I make two blocks on the side of a wall. One block is for the inlet slot and the other for the outlet slot. My question is: When I make the block for inlet slot I am defining one patch of the block as the inlet patch and the other 5 side are walls? If am not defining the other side, the simulation stops because of "empty patches".
Maybe can somebody give me excample for simulation inlet slot in 3D rooms? It whould help me.
Thanks
Myting
Old   September 20, 2006, 06:43
Default Hi Myting Post the case or
atzaru
Hi Myting
Post the case or send it to me by email and i will have a look, i think the geometry is somehow wrong
atzaru@gmail.com
atzaru
Old   September 20, 2006, 06:45
Default Hi Myting, Please post you
atzaru
Hi Myting,
Please post your case or send it to me by email and i will have a look
atzaru at gmail.com
Atzaru
Old   September 21, 2006, 10:42
Default Hi, my case: /*---------
myting
my case:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
// FoamX Case Dictionary.
FoamFile
version 2.0;
format ascii;
root "/home/cfd1/OpenFOAM/cfd1-1.3/run/tutorials/buoyantSimpleFoam";
case "office";
instance "constant/polyMesh";
local "";
class dictionary;
object blockMeshDict;
arguments "/home/cfd1/OpenFOAM/cfd1-1.3/run/tutorials/buoyantSimpleFoam/office" off;
convertToMeters 1;
vertices
(0 0 0)
(10 0 0)
(10 5 0)
(0 5 0)
(0 0 10)
(10 0 10)
(10 5 10)
(0 5 10)
(2 4 0)
(3 4 0)
(3 4.2 0)
(2 4.2 0)
(2 4 0.1)
(3 4 0.1)
(3 4.2 0.1)
(2 4.2 0.1)
(7 4 0)
(8 4 0)
(8 4.2 0)
(7 4.2 0)
(7 4 0.1)
(8 4 0.1)
(8 4.2 0.1)
(7 4.2 0.1)
blocks
hex (0 1 2 3 4 5 6 7) (40 40 40) simpleGrading (1 1 1)
hex (8 9 10 11 12 13 14 15) (20 20 20) simpleGrading (1 1 1)
hex (16 17 18 19 20 21 22 23) (20 20 20) simpleGrading (1 1 1)
edges
patches
wall floor
(1 5 4 0)
wall ceiling
(3 7 6 2)
wall fixedWalls
(0 4 7 3)
(2 6 5 1)
(0 3 2 1)
(4 5 6 7)
patch inlet
(12 13 14 15)
patch fixedWallsInlet
(8 11 10 9)
(9 10 14 13)
(15 11 8 12)
(14 10 11 15)
(13 12 8 9)
patch Outlet
(20 21 22 23)
patch fixedWallsOutlet
(16 19 18 17)
(17 18 22 21)
(23 19 16 20)
(22 18 19 23)
(17 21 20 16)
mergePatchPairs
Old   September 24, 2006, 16:55
Default 1- Actually it seems to me you
Adrian Magda
amagda is on a distinguished road
1- Actually it seems to me you describe in a wrong way your geometry. First u make a room (the first block). After that u make two separate blocks for inlet and outlet. The inlet-outlet ports should be located on the face of the first block (patches).
2- As a general rule the blocks should share common faces, yours are not connected what so ever
adi
amagda is offline   Reply With Quote
Old   September 25, 2006, 02:23
Default Hi, thanks for you answer.
myting
thanks for you answer. Can you give me an example? It whould be nice for me.
So, I don't need the other blocks for Inlet and Outletslot? It is easier to make only a patch (face) on one site of the roomwall?
How can I connected the block with each other? I thought the Mesher do this kind of job???
Thank you
Myting
Old   September 25, 2006, 03:51
Default ok i have a small tutorial
Adrian Magda
ok
i have a small tutorial with some cases i presented in our department... i will post them today or tomorrow
adrian
Old   September 25, 2006, 14:19
Default Hi You can download the tut
Adrian Magda
Hi
You can download the tutorial here
http://www.schunternet.de/~amagda/cf...M_tutorial.odt
Any comments, corrections, new cases will be welcome, i am sure it can be made a lot better.
Adi
Old   September 26, 2006, 03:46
Default Thank you very much for your h
myting
Thank you very much for your help...
Myting
Old   September 28, 2006, 02:30
Default Hi Adrian, I think, the las
myting
Hi Adrian,
I think, the last case in your tutorial is not complete. The "blockMeshDict" has not enough vertex to make all blocks? Can you check your file please? Thank you very much...
Myting
Old   September 28, 2006, 17:01
Default Yup i just corrected ad
  #11
Adrian Magda
Yup
i just corrected
adi
Old   October 1, 2006, 09:02
Default Hi Adrian, I tried your las
  #12
myting
Hi Adrian,
I tried your last case but it is impossible. I don't know why, but I got "nan" in solution always. Can you send me your full case files?
Thank you.
Myting
Floworks for simulation of airflow in large rooms. kajaken FloEFD, FloWorks & FloTHERM 1 October 28, 2008 14:58
Slot jet impinging on cylinder Diz CFX 0 September 24, 2007 22:34
Slot jet in cross flow. Hamdy Phoenics 0 March 5, 2006 05:01
impinging slot-jet ramesh.... FLUENT 1 April 6, 2005 11:35
How to do turbulent bc on the injection slot? peter.zhao Main CFD Forum 3 June 26, 2004 08:05
