To get the magnitude of volVectorField
Old   November 15, 2006, 06:29
Default Hi All, Can anyone please
susana
Hi All,
Can anyone please inform me as to how I can get the magnitude of a vector defined as volVectorField, which I belive is of type GeometricField. I have tried mag() an a lot of other manipulations. In essence I need to get the magnitude of the velocity U (defined as volVectorField) and multiply it with other values defined as dimensionedScalar. I am getting a compile error.
Please please help.
Thanks in advance,
Susan.
Old   November 15, 2006, 08:13
Default Hi Susan, something like
cosimo bianchini
cosimobianchini is on a distinguished road
Send a message via Skype™ to cosimobianchini
Hi Susan,
something like
dimensionedScalar C ("C",p.dimensions(),1000.0) ;
volScalarField magU = C*mag(U);
should work.
U is again the velocity defined as volVectorField
hope it helps
Cosimo
Cosimo Bianchini
Ergon Research s.r.l.
Via Panciatichi, 92
50127 Florence - ITALY
Tel: +39 055 0763716
Mob: +39 320 9460153
e-mail: cosimo.bianchini@ergonresearch.it
URL: www.ergonresearch.it
cosimobianchini is offline   Reply With Quote
Old   November 15, 2006, 08:21
Default Thanks for the response, my pr
susana
Thanks for the response, my problem is like this
scalar x, y, z
z = x*y*mag(U) where U is volVectorField
gives me an error
no match for 'operator=' in 'Re = Foam::operator/(const Foam::tmp<foam::geometricfield<type,> >&, const Foam::dimensioned<double>&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::dimensioned<double>&)((const Foam::dimensioned<double>*)(& nu))))'
/home/abrahasm/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/dimensionedScalarFwd .H:45: note: candidates are: Foam::dimensioned<double>& Foam::dimensioned<double>::operator=(const Foam::dimensioned<double>&)
Please help.
Old   November 15, 2006, 08:32
Default If with scalar you mean just d
cosimo bianchini
If with scalar you mean just dimensionedScalar the problem is:
z must be a volScalarField
Cosimo
Cosimo Bianchini
Via Panciatichi, 92
Old   November 15, 2006, 08:34
Default Hi Susan, you get the error b
Tommaso Lucchini
lucchini is on a distinguished road
Hi Susan,
you get the error because you try to assign to a scalar variable the product between a scalarField and a volScalarField.
You can get it working if you write:
volScalarField z = x*y*mag(U)
I hope it has been useful,
bye
Tommaso
lucchini is offline   Reply With Quote
Old   November 16, 2006, 07:53
Default Thanks so much! It takes a whi
susana
Thanks so much! It takes a while to understand how the different classes are structured.
Taking the absolute value of a volVectorField or a volTensorField kupiainen OpenFOAM 3 July 25, 2019 14:00
Combining 3 volScalarFields to form a volVectorField srinath OpenFOAM 1 August 13, 2008 02:27
How to update volVectorField velocity swlee OpenFOAM Running, Solving & CFD 0 June 18, 2008 05:57
VolVectorField of complex numbers quba OpenFOAM 0 December 17, 2007 09:06
Why doesnbt the macro forall work for the volVectorField variable siwen OpenFOAM Running, Solving & CFD 2 February 24, 2006 16:27
