Problem with running FoamX in a distributed environment
Old   March 28, 2007, 06:42
Default Hi All, I am having a prob
susana
Hi All,
I am having a problem and will be truly grateful if someone can help me.
I have 2 machines A & B, A running Foam on Fedora 6 (32-bit) and B running Foam on SuSE 10 (64 bit). I ran the runFoamXHB script on B (i.e started name service on B) and tried to start FoamX on A to connect to machine B's name service. The FoamX GUI starts (with no host details on it) and I get an error "Default Name service could not be contacted"
I have been reading through a lot of posts and did what was mentioned there but still cannot solve the problem. What I did:
1. copied ns.ref in machine B to machine A (directory../OpenFOam/...Apps/FoamX/)
2. changed the FoamXClient.cfg in both A and B to point Host = B and port = 1234.
3. changed /etc/hosts on both machines to include both own and each other's hostnames
4. no firewall running on both machines.
5. When all the above still did not solve the problem, I changed the port number to 123456...but still have same problem..
6. I ran nsd on both A and B locally and a sample CORBA server and client program on the same machine can see and connect to it.
7. I can telnet, ftp from both machines.
Now I am really stuck and dont know what other options to try....can someone PLEASE HELP.
Thanks a lot,
Susan
Old   March 28, 2007, 18:11
Default Do an iordump/iordecode on tha
Mattijs Janssens
mattijs is on a distinguished road
Do an iordump/iordecode on that ns.ref. Pick up B's fully resolved name from there and see if you can telnet to the nsd using that:
telnet fully-resolved-name 1234
mattijs is offline   Reply With Quote
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Problem running FoamX ianz8802 OpenFOAM Installation 11 March 23, 2007 12:22
Running FoamX vivekjoshi OpenFOAM Installation 0 November 5, 2006 17:13
problem in running FoamX in Open FOAM Gaurav Main CFD Forum 3 May 10, 2006 06:06
