Problem about setFields
Like Tree4Likes
Old   January 24, 2018, 12:59
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Shafik,
Did you update the boxToCell details inside the setFieldsDict?
My guess is that your "box" is outside of your domain i.e. use checkMesh to check the bounds of your domain and make sure the boxToCell is inside this (be careful of units).
Philip
bigphil is offline   Reply With Quote
Old   January 24, 2018, 13:25
Default Thanks
  #22
Shafik Walakaka
walakaka is on a distinguished road
Originally Posted by bigphil View Post
Hi Shafik,
Philip
Thanks for your help Philip, it was the cause of the issue! Didnt realize that the dimension conversion in blockMeshDict does not apply to setFieldsDict causing my box to be outside my domain.
Thanks heaps again!
walakaka is offline   Reply With Quote
Old   December 9, 2018, 00:59
Default setFieldsDict - in the form of sphere for 1D solver
  #23
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Hello everyone,
My topic of research is on coke oven process using 1D solver. Heat transfer is considered to be one-dimensional for the lump coal (placed inside the domain).
To define geometrical regions in the form of sphere (coal) inside my domain, I adopted setFieldsDict file ~ to initialize fields. But unfortunately, the set field directory gives shapes of sphere for 2D or 3D modeling in better way - whereas not in the case of 1D modeling.
I am hereby including my blockMeshDict file (only blocks) and setFieldsDict file.
blockMeshDict file:
convertToMeters 0.01;
vertices
(0 0 0) (15 0 0) (15 1 0) (0 1 0) (0 0 7) (15 0 7) (15 1 7) (0 1 7)
blocks
hex (0 1 2 3 4 5 6 7) (1250 1 1) simpleGrading (1 1 1)
edges
setFieldsDict file:
defaultFieldValues
volScalarFieldValue C 0
regions
sphereToCell
centre (0.03 0 0.03);
radius 0.02;
fieldValues
volScalarFieldValue C 800
Dear Foamers, I want to know the possibility of creating fields in the form of sphere inside my domain for 1D solver using setFieldsDict.
If not setfieldDict, is there any relevant options to initialize fields for 1D solver ?
Kindly share your ideas plzz..
Thank you
Kummi is offline   Reply With Quote
Old   December 9, 2018, 01:15
Kumaresh
As a result, the initialized field in paraFoam [Attachment] ~ is not in the form of sphere because the set field dimensions is influenced only in X- directional for 1D mesh.
SetFields runs with no errors but doesnbt change fields adamsview OpenFOAM Pre-Processing 3 December 12, 2014 22:03
InterDyMFoam and problem with setFields chris_sev OpenFOAM Running, Solving & CFD 1 March 23, 2009 22:23
Setfields inoutlet and water and air patches erik023 OpenFOAM Pre-Processing 1 September 29, 2008 11:05
Regarding setFields file 21kalee OpenFOAM Running, Solving & CFD 0 January 14, 2008 06:42
problem in solving "wave generation" problem san FLUENT 2 April 4, 2006 00:37
