Algebraic tensor operations
Old   July 17, 2007, 11:20
Default Cross Product: I tried to c
Maka Mohu
maka is on a distinguished road
Cross Product:
I tried to calculate a cross product by a code like
A ^ U
A is dimensionedVector
U is volVectorField
I got the error:
error: no match for 'operator^' in 'Foam::operator==(const Foam::tmp<foam::fvmatrix<type> >&, const Foam::dimensioned<type>&) [with Type = Foam::Vector<double>](((const Foam::dimensioned<foam::vector<double> >&)((const Foam::dimensioned<foam::vector<double> >*)(& Foam::operator-(const Foam::dimensioned<type>&, const Foam::dimensioned<type>&) [with Type = Foam::Vector<double>](((const Foam::dimensioned<foam::vector<double> >&)((const Foam::dimensioned<foam::vector<double> >*)(& Foam::operator*(const Foam::dimensioned<double>&, const Foam::dimensioned<type>&) [with Type = Foam::Vector<double>](((const Foam::dimensioned<foam::vector<double> >&)((const Foam::dimensioned<foam::vector<double> >*)(& omegaF)))))))))))) ^ U'
/data/maka/OpenFOAM/linuxAMD64/gcc-4.1.0/bin/../lib/gcc/x86_64-unknown-linux-gnu /4.1.0/../../../../include/c++/4.1.0/bits/ios_base.h:165: note: candidates are: std::_Ios_Iostate std::operator^(std::_Ios_Iostate, std::_Ios_Iostate)
/data/maka/OpenFOAM/linuxAMD64/gcc-4.1.0/bin/../lib/gcc/x86_64-unknown-linux-gnu /4.1.0/../../../../include/c++/4.1.0/bits/ios_base.h:127: note: std::_Ios_Openmode std::operator^(std::_Ios_Openmode, std::_Ios_Openmode)
/data/maka/OpenFOAM/linuxAMD64/gcc-4.1.0/bin/../lib/gcc/x86_64-unknown-linux-gnu /4.1.0/../../../../include/c++/4.1.0/bits/ios_base.h:87: note: std::_Ios_Fmtflags std::operator^(std::_Ios_Fmtflags, std::_Ios_Fmtflags)
Any idea how to define such operation:
I wanted the cross product to be applied to the vector A with each vector of the volVectorField. Thanks.
Best regards,
Maka.
maka is offline   Reply With Quote
Old   July 17, 2007, 15:04
Default this is to be done as a part o
Maka Mohu
this is to be done as a part of equation definition like Ueqn for example in icoFoam.
Old   July 17, 2007, 15:40
Default it was operator precedence pro
Maka Mohu
it was operator precedence problem, that is discussed in here.
the solution is to use the (A ^ U) instead of A ^ U
Nonbasic mathematical operations ngj OpenFOAM 0 September 26, 2008 18:16
FvPatch operations maka OpenFOAM Post-Processing 4 July 10, 2008 08:36
Cleaning up operations Vidya Raja FLUENT 3 May 22, 2006 15:17
body operations fintan CFX 3 December 1, 2005 00:05
GET_GVAR operations? Cujo CFX 3 July 23, 2003 12:27
