ScalarField division
Old   August 26, 2007, 18:57
Default I do the following operation b
Maka Mohu
maka is on a distinguished road
I do the following operation but it gives wrong result (1.22005e-312):
const scalarField& ry = patch().deltaCoeffs();
// magnitude of patch-normal distance from face to cell centers:
const scalarField& yn= 1.0/ry;
but if I make a loop and use:
const scalarField& yn= 1.0/ry[facei];
it gives correct result. How can I do mathematical operations that contain scalarFields and scalars without looping? Thanks.
Best regards,
Maka
maka is offline   Reply With Quote
Old   August 26, 2007, 19:16
Default Classic mistake: reference to
Hrvoje Jasak
Classic mistake: reference to a temporary: if you do:
scalarField yn= 1.0/ry;
all will be well. Operation 1/ry will return a COPY, i.e. a new field. You took a reference to it, which is a memory error - that's the little & bit after the scalarField.
I bet you already know this - if not, time for a careful look at a good C++ book.
Got it?
Hrv
Hrvoje Jasak
Old   August 27, 2007, 06:10
Default Thanks Hrv for the explanation
Maka Mohu
Thanks Hrv for the explanation.
Best regards,
Maka.
How to sum up scalarField wese OpenFOAM Running, Solving & CFD 2 August 19, 2019 18:30
How to set up an AUTO_WRITE scalarField xiao OpenFOAM Running, Solving & CFD 9 July 22, 2010 04:23
max for scalarField maka OpenFOAM Bugs 9 February 19, 2009 10:43
Division by zero vitke OpenFOAM Running, Solving & CFD 5 September 1, 2008 06:35
[CGNS] Computing a cellcentered scalarField from a vertexcentered scalarField mbeaudoin OpenFOAM Meshing & Mesh Conversion 10 February 22, 2007 08:43
