FoamX not starting Javarelated error
Old   June 21, 2007, 12:38
Default Although I have a Java-VM inst
Alexander Grahn
agrahn is on a distinguished road
Although I have a Java-VM installed in the system (sun-jdk-1.4.2.14) I put the recommended version (j2sdk1.4.2_05) into the `linux' subdirectory of $HOME/OpenFOAM and adjusted `JAVA_HOME' $HOME/OpenFOAM/OpenFOAM-1.4/.bashrc accordingly.
This is what foamInstallationTest outputs:
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/grahn/OpenFOAM/OpenFOAM-1.4 yes yes yes
$FOAM_USER_APPBIN ...-1.4/applications/bin/linuxGcc4DPOpt yes yes no
$FOAM_APPBIN ...-1.4/applications/bin/linuxGcc4DPOpt yes yes yes
$WM_DIR /home/grahn/OpenFOAM/OpenFOAM-1.4/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH /home/grahn/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no
$MICO_ARCH_PATH ...mico-2.3.12/platforms/linuxGcc4DPOpt yes yes yes
$LAM_ARCH_PATH ...c/lam-7.1.2/platforms/linuxGcc4DPOpt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Software versions
Software Version Location
gcc 4.1.2 /usr/bin/gcc
java 1.4.2_05 /home/grahn/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
gzip 1.3.12 /bin/gzip
tar 1.3.12 /usr/bin/tar
icoFoam ...M/OpenFOAM-1.4/applications/bin/linuxGcc4DPOpt/icoFoam
However, FoamX crashes soon after starting:
Starting NameServer with inet:fwss41:1234 ...
Starting FoamX Host Browser with inet:fwss41:1234 ...
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : FoamXHostBrowser
Date : Jun 21 2007
Time : 17:32:24
Host : fwss41
PID : 23329
Root :
Case :
Nprocs : 1
HostBrowser running.....
Setting LANG to en_EN
Using jar /home/grahn/OpenFOAM/OpenFOAM-1.4/applications/utilities/preProcessing
/FoamX/lib/FoamX.jar
/FoamX/lib/jlfgr-1_0.jar
Exception in thread "main" java.lang.NoClassDefFoundError: FoamX/App
/home/grahn/OpenFOAM/OpenFOAM-1.4/bin/runFoamXHB: line 139: 23329 Killed
FoamXHostBrowser -ORBNamingAddr $myIOP
runFoamXHB : cleanup
runFoamXHB: Killing name server nsd(pid 23325).
/home/grahn/OpenFOAM/OpenFOAM-1.4/bin/runFoamXHB: line 66: 23325 Killed
nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref < /dev/null
What is wrong? Help is greatly appreciated.
(I am running Gentoo-Linux.)
Alexander
agrahn is offline   Reply With Quote
Old   June 22, 2007, 10:39
Default I could solve the problem by r
Alexander Grahn
I could solve the problem by recompiling all Java stuff in the OpenFOAM source directory using the Java compiler of the Java-installation being in use (as configured by JAVA_HOME env variable):
For those who are interested in the required steps:
foam
find . -name '*.java' -print | xargs touch
Allwmake
Alexander
Old   June 28, 2007, 03:11
Default Thank you Alexander for report
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Thank you Alexander for reporting the solution.
msrinath80 is offline   Reply With Quote
Old   June 28, 2007, 09:41
Default BTW, option `clean' would be a
Alexander Grahn
BTW, option `clean' would be a _very_ useful addition to the Allwmake script. Or am I missing something?
Alexander
Old   June 28, 2007, 09:50
Default You are. http://www.cfd-online
Hrvoje Jasak
You are. For cleaning, try wclean for a single app or library or at OpenFOAM level wcleanAll.
Enjoy,
Hrv
Hrvoje Jasak
Old   October 20, 2007, 06:33
Default When i use Alexander suggestio
Marhamat Zeinali
marhamat is on a distinguished road
When i use Alexander suggestion i get below messages in konsole:
Making dependency list for source file writeFuns.C
could not open file interpolatePointToCell.H for source file writeFuns.C
Making dependency list for source file writePatchGeom.C
could not open file interpolatePointToCell.H for source file writePatchGeom.C
Making dependency list for source file writeFaceSet.C
could not open file interpolatePointToCell.H for source file writeFaceSet.C
Making dependency list for source file writePointSet.C
could not open file interpolatePointToCell.H for source file writePointSet.C
Making dependency list for source file writeSurfFields.C
could not open file interpolatePointToCell.H for source file writeSurfFields.C
Making dependency list for source file vtkMesh.C
Making dependency list for source file vtkTopo.C
make[3]: Leaving directory `/home/hydrolab/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/da taConversion/foamToVTK'
make[3]: Entering directory `/home/hydrolab/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/da taConversion/foamToVTK'
SOURCE=foamToVTK.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/hydrolab/OpenFOAM/OpenFOAM-1.4.1/src/lagrangian/basic/lnInclude -I/home/hydrolab/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/hydrolab/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -I/home/hydrolab/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/g raphics/PVFoamReader/vtkFoam/lnInclude -IlnInclude -I. -I/home/hydrolab/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/foamToVTK.o
In file included from writeFuns.H:244,
from foamToVTK.C:90:
writeFunsTemplates.C:30:36: error: interpolatePointToCell.H: No such file or directory
writeFunsTemplates.C: In static member function 'static void Foam::writeFuns::write(std::ostream&, bool, const Foam::GeometricField<type,>&, const Foam::vtkMesh&) [with Type = double]':
internalWriterTemplates.C:40: instantiated from 'void Foam::internalWriter::write(const Foam::PtrList<foam::geometricfield<type,> >&) [with Type = double, PatchField = Foam::pointPatchField, GeoMesh = Foam::pointMesh]'
foamToVTK.C:518: instantiated from here
writeFunsTemplates.C:123: error: 'interpolatePointToCell' was not declared in this scope
writeFunsTemplates.C: In static member function 'static void Foam::writeFuns::write(std::ostream&, bool, const Foam::GeometricField<type,>&, const Foam::vtkMesh&) [with Type = Foam::Vector<double>]':
internalWriterTemplates.C:40: instantiated from 'void Foam::internalWriter::write(const Foam::PtrList<foam::geometricfield<type,> >&) [with Type = Foam::Vector<double>, PatchField = Foam::pointPatchField, GeoMesh = Foam::pointMesh]'
foamToVTK.C:519: instantiated from here
writeFunsTemplates.C: In static member function 'static void Foam::writeFuns::write(std::ostream&, bool, const Foam::GeometricField<type,>&, const Foam::vtkMesh&) [with Type = Foam::SphericalTensor<double>]':
internalWriterTemplates.C:40: instantiated from 'void Foam::internalWriter::write(const Foam::PtrList<foam::geometricfield<type,> >&) [with Type = Foam::SphericalTensor<double>, PatchField = Foam::pointPatchField, GeoMesh = Foam::pointMesh]'
foamToVTK.C:520: instantiated from here
writeFunsTemplates.C: In static member function 'static void Foam::writeFuns::write(std::ostream&, bool, const Foam::GeometricField<type,>&, const Foam::vtkMesh&) [with Type = Foam::SymmTensor<double>]':
internalWriterTemplates.C:40: instantiated from 'void Foam::internalWriter::write(const Foam::PtrList<foam::geometricfield<type,> >&) [with Type = Foam::SymmTensor<double>, PatchField = Foam::pointPatchField, GeoMesh = Foam::pointMesh]'
foamToVTK.C:521: instantiated from here
writeFunsTemplates.C: In static member function 'static void Foam::writeFuns::write(std::ostream&, bool, const Foam::GeometricField<type,>&, const Foam::vtkMesh&) [with Type = Foam::Tensor<double>]':
internalWriterTemplates.C:40: instantiated from 'void Foam::internalWriter::write(const Foam::PtrList<foam::geometricfield<type,> >&) [with Type = Foam::Tensor<double>, PatchField = Foam::pointPatchField, GeoMesh = Foam::pointMesh]'
foamToVTK.C:522: instantiated from here
make[3]: *** [Make/linux64GccDPOpt/foamToVTK.o] Error 1
make[2]: *** [foamToVTK] Error 2
make[2]: Leaving directory `/home/hydrolab/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/da taConversion'
make[1]: *** [dataConversion] Error 2
make[1]: Leaving directory `/home/hydrolab/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing'
make: *** [postProcessing] Error 2
+ '[' 0 = 1 -a '' = doc ']'
hydrolab@linux-zah4:~/OpenFOAM/OpenFOAM-1.4.1>
Regards
Marhamat
marhamat is offline   Reply With Quote
Starting FoamX error jaswi OpenFOAM Installation 15 February 7, 2012 15:53
Problem with starting FoamX laker OpenFOAM Installation 2 May 13, 2008 10:34
FoamX starting on Fedora 8 x86_64 and i386 Error nsd ORBIIOPAddr %24myIOP ior %24FOAMX_CONFIGnsref %2360 devnull rationaalinen OpenFOAM Pre-Processing 6 December 2, 2007 12:40
Java error while starting FoamX erydj OpenFOAM Pre-Processing 2 May 4, 2007 09:53
Java error while starting FoamX cfdengineering OpenFOAM Pre-Processing 16 June 28, 2006 21:02
