FoamX Startup Error libXpso6
Old   November 9, 2007, 16:38
Default Hello, I have installed Ope
craig
I have installed OpenFOAM on an X86_64 machine running RHEL 5 but cannot seem to get FoamX running. I have successfully created symbolic links for libssl.so.0.9.8b, libcrypto.so.0.9.8b, and libebl_x86_64-0.125.so. However, I have not been able to figure out how to resolve the following error (which I believe is related to libX.s0.6 symbolic link).
[cmerrill@penguin ~]$ FoamX
Starting NameServer with inet:penguin.ara.wan:1234 ...
Starting FoamX Host Browser with inet:penguin.ara.wan:1234 ...
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : FoamXHostBrowser
Date : Nov 09 2007
Time : 15:20:34
Host : penguin.ara.wan
PID : 3688
Root :
Case :
Nprocs : 1
HostBrowser running.....
Setting LANG to en_EN
Using jar /home/cmerrill/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/preProcessing/Foam X/lib/FoamX.jar
Using jar /home/cmerrill/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/preProcessing/Foam X/lib/jlfgr-1_0.jar
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/cmerrill/OpenFOAM/linux64/j2sdk1.4.2_05/jre/lib/i386/libawt.so: libXp.so.6: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.jav a:1586)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java :1503)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at sun.security.action.LoadLibraryAction.run(LoadLibr aryAction.java:50)
at java.security.AccessController.doPrivileged(Native Method)
at sun.awt.NativeLibLoader.loadLibraries(NativeLibLoa der.java:38)
at sun.awt.DebugHelper.<clinit>(DebugHelper.java:29)
at java.awt.Component.<clinit>(Component.java:506)
/home/cmerrill/OpenFOAM/OpenFOAM-1.4.1/bin/runFoamXHB: line 139: 3688 Killed FoamXHostBrowser -ORBNamingAddr $myIOP
runFoamXHB : cleanup
runFoamXHB: Killing name server nsd(pid 3684).
Any suggestions? I am a newbie. Thank you.
Old   November 9, 2007, 19:39
Default Search the forum for posts tha
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Search the forum for posts that suggest ways to solve the libXp.so.6 issue.
Eg: http://www.cfd-online.com/OpenFOAM_D...ges/1/394.html
msrinath80 is offline   Reply With Quote
GAMBIT STARTUP error Farhat FLUENT 3 February 9, 2010 14:52
FoamX error lawrencelkl OpenFOAM Installation 5 May 23, 2008 02:29
FoamX libXpso6 wrong ELF class error abanerj3 OpenFOAM Pre-Processing 2 May 18, 2008 16:32
FoamX error derath OpenFOAM Pre-Processing 2 April 25, 2007 06:51
Gambit startup error: libXp.so.6 cannot be found Patrice Guay FLUENT 5 August 10, 2005 14:03
