DieselFoam and ReactingFoam
Old   May 13, 2008, 07:49
Default Hello to everyone! I'm sorry
Matteo Rosa Sentinella
matteo_rosa_sentinella is on a distinguished road
Hello to everyone!
I'm sorry if I'm doing a silly question but I'm new both in linux and OpenFoam. I would like to run the reactingFoam tutorial but it's not set up in openFoam. In the directory of the two solver the FoamX directory doesn't exist.. and I'm not able to configure it by myself.
Can someone help me?
thanks,
Matt
matteo_rosa_sentinella is offline   Reply With Quote
Old   May 13, 2008, 11:17
Default Matt, The wiki has an examp
E. David Huckaby
david_h is on a distinguished road
Matt,
The wiki has an example case for reactingFoam:
http://openfoamwiki.net/index.php/Tu..._firstTutorial
If you have stability problems with the simulation, try diluting the fuel and oxidizer inlets with nitrogen.
Dave
david_h is offline   Reply With Quote
Old   May 14, 2008, 03:56
Default David, that's the point! I'm
David,
that's the point! I'm trying to run that tutorial but FoamX says: "getApplication::Invalid application class name 'dieselFoam'". basically I think that dieselFoam is not configured for FoamX, and actually the directory FoamX with the .cfg files in the solver's directory does not exist. I don't know how to generate that directory....
Old   May 14, 2008, 10:15
Default Matt, Each of the solvers w
E. David Huckaby
Matt,
Each of the solvers which has been configured for FoamX has a configuration file in the source directory of the particular solver( "$FOAM_APP/solvers/<category>/<solver>/FoamX" ). You would need to make a similar directory and associated files for reactingFoam or dieselFoam("$FOAM_APP/combustion/reactingFoam/FoamX").
Have you tried running the solver from the command line ?
Dave
Old   September 28, 2009, 11:35
Default reaction rate by chemkin
mehdi
mehdi-combustion is on a distinguished road
Dear members,
I have a difficulty with reactingFoam.
When I calculate reactingFoam tutorial or dieselenginfoam tutorial, the reaction rate is always Zero. I have switched on the chemistry and combustion as well as using a high temperature ignition region, however, regardless of the temperature and Arrhenius parameters that I used in chem.inp, the reaction rate is always zero. I should mentioned that other transport properties and equation for species (YEq) is properly solved. The problem is just in the calculation of reaction rate.
Any help!
mehdi-combustion is offline   Reply With Quote
DieselFoam spray thumthae OpenFOAM Running, Solving & CFD 98 December 24, 2014 16:55
Find the total amount of a species in reactingFoam or dieselFoam alexandrepereira OpenFOAM Post-Processing 0 February 21, 2009 16:58
Problem in dieselFoam skherad OpenFOAM Running, Solving & CFD 0 July 6, 2006 05:48
Problem in dieselFoam skherad OpenFOAM Running, Solving & CFD 0 July 6, 2006 05:45
About dieselFoam tsjb00 OpenFOAM Running, Solving & CFD 3 August 16, 2005 17:59
