OpenFOAM 13 FoamX libelfso0 and Fedora Core 4
Old   September 19, 2007, 14:35
Default Once, just for once why doesn'
  #21
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Once, just for once why doesn't anybody ever read the installation instructions[1] and avoid all such problems related to GLIBC_2.x not being found. If you use the Gcc, paraview and java provided with OpenFoam there will be no problems. Please run the foamInstallationTest script and paste the output here.
[1] http://www.openfoam.org/doc/README
msrinath80 is offline   Reply With Quote
Old   November 20, 2007, 18:25
Default I have a problem with starting
  #22
Onur Dundar
onurdundar is on a distinguished road
I have a problem with starting the FoamX and at the end reply Srinath said that paste the foamInstallationTest script. I did it and How I can solve the problem?
Thanks
Onur
Executing: /home/dundar/OpenFOAM/OpenFOAM-1.4.1/.bashrc
Executing: /home/dundar/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/ensightFoam/bashrc
Executing: /home/dundar/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/paraview/bashrc
Executing bash:
Checking basic setup...
Shell: bash
Host: localhost.localdomain
OS: Linux version 2.6.20-2936.fc7xen
User: dundar
User_config: /home/dundar/.bashrc
Foam_config: /home/dundar/.OpenFOAM-1.4.1/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/dundar/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/dundar/OpenFOAM/dundar-1.4.1 yes no
$FOAM_JOB_DIR /home/dundar/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/dundar/OpenFOAM/OpenFOAM-1.4.1 yes yes yes
$FOAM_USER_APPBIN ...1.4.1/applications/bin/linuxGccDPOpt yes yes no
$FOAM_APPBIN ...1.4.1/applications/bin/linuxGccDPOpt yes yes yes
$WM_DIR ...dundar/OpenFOAM/OpenFOAM-1.4.1/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH .../dundar/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no
$MICO_ARCH_PATH .../mico-2.3.12/platforms/linuxGccDPOpt yes yes yes
$LAM_ARCH_PATH --------- env variable not set --------- yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...nFOAM/dundar-1.4.1/lib/linuxGccDPOpt yes yes no
Software versions
Software Version Location
gcc 4.2.1 /home/dundar/OpenFOAM/linux/gcc-4.2.1/bin/gcc
java 1.4.2_05 /home/dundar/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
gzip 1.3.11 /usr/bin/gzip
tar 1.3.11 /bin/tar
icoFoam .../OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
...localhost.localdomain Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
Base configuration ok.
Critical systems ok.
[dundar@localhost ~]$ home/dragosm>rpm -q -a
bash: home/dragosm: No such file or directory
[dundar@localhost ~]$ FoamX
Starting NameServer with inet:localhost.localdomain:1234 ...
nsd: error while loading shared libraries: libssl.so.0.9.8: cannot open shared object file: No such file or directory
onurdundar is offline   Reply With Quote
Old   November 20, 2007, 19:22
Default Go here and search for "libssl
  #23
Go here[1] and search for "libssl"
[1] http://www.cfd-online.com/cgi-bin/Op...cus/search.cgi
Old   June 24, 2008, 03:01
Default Hi DARIO! Have you solved your
  #24
M M Karim
mdmk is on a distinguished road
Hi DARIO! Have you solved your problem? I also have same problem. The error messages are as follows:
[mmkarim@localhost@localdomain ~]$ foamInstallationTest
Executing /home/mmkarim/OpenFOAM/OpenFOAM-1.4.1/bin/foamInstallationTest:
Shell: bash
Host: localhost@localdomain
OS: Linux version 2.6.15-1.2054_FC5
User: mmkarim
User_config: /home/mmkarim/.bashrc
Foam_config: /home/mmkarim/.OpenFOAM-1.4.1/bashrc sourced correctly.
$WM_PROJECT_INST_DIR /home/mmkarim/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/mmkarim/OpenFOAM/mmkarim-1.4.1 yes no
$FOAM_JOB_DIR /home/mmkarim/OpenFOAM/jobControl no yes
$WM_PROJECT_DIR /home/mmkarim/OpenFOAM/OpenFOAM-1.4.1 yes yes yes
$WM_DIR ...mkarim/OpenFOAM/OpenFOAM-1.4.1/wmake yes yes yes
$JAVA_PATH ...mmkarim/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no
$FOAM_USER_LIBBIN ...FOAM/mmkarim-1.4.1/lib/linuxGccDPOpt yes yes no
Software versions
gcc 4.2.1 /home/mmkarim/OpenFOAM/linux/gcc-4.2.1/bin/gcc
java 1.4.2_05 /home/mmkarim/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
gzip 1.3.5 /usr/bin/gzip
tar 1.3.5 /bin/tar
Action Result Crit
...localhost@localdomain Successful yes
[mmkarim@localhost@localdomain ~]$ FoamX
Starting NameServer with inet:localhost@localdomain:1234 ...
Starting FoamX Host Browser with inet:localhost@localdomain:1234 ...
FoamXHostBrowser: error while loading shared libraries: /home/mmkarim/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libFoamX.so: cannot restore segment prot after reloc: Permission denied
runFoamXHB : cleanup
runFoamXHB: Killing name server nsd(pid 9535).
/home/mmkarim/OpenFOAM/OpenFOAM-1.4.1/bin/runFoamXHB: line 66: 9535 Killed nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null
Pl. tell me what I should do.
MMK
mdmk is offline   Reply With Quote
FoamX libelfso0 nunoinlux OpenFOAM Bugs 6 September 11, 2007 21:13
fluent on fedora core 6 Jeferson FLUENT 7 February 9, 2007 15:43
FoamX Error after upgrade to Fedora Core 6 philippose OpenFOAM Installation 5 October 31, 2006 13:36
FoamX libelfso0 mockealm OpenFOAM Installation 6 June 29, 2006 16:37
FEDORA core 2 and FLUENT tuks FLUENT 2 July 13, 2005 01:23
