How to handle it
Old   August 20, 2008, 03:51
Default hi, i am doing a simulation a
weihong yao
ivanyao is on a distinguished road
hi,
i am doing a simulation about wind pressure on a 6m cube,i put the 6m*6m*6m cube into 192m*120m*60m box.when i extrudeMesh,it show follow message;
FOAM FATAL ERROR : Trying to specify a boundary face 4(0 3 7 4) on the face on cell 14 which is either an internal face or already belongs to some other patch. This is face 0 of patch 2 named front.#0 Foam::error::printStack(Foam:stream&)
#1 Foam::error::abort()
#2 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::List<foam::word> const&)
#3 Foam::blockMesh::createTopology(Foam::IOdictionary &)
#4 Foam::blockMesh::blockMesh(Foam::IOdictionary&)
#5 main
#6 __libc_start_main
#7 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122
From function polyMesh::polyMesh
const IOobject& io,
const pointField& points,
const cellShapeList& cellsAsShapes,
const faceListList& boundaryFaces,
const wordList& boundaryPatchTypes,
const wordList& boundaryPatchNames,
const word& defaultBoundaryPatchType
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 482.
FOAM aborting
my blockMesh file are:
convertToMeters 1;
vertices
(-3 -3 0)
(3 -3 0)
(3 3 0)
(-3 3 0)
(-3 -3 6)
(3 -3 6)
(3 3 6)
(-3 3 6)
(-39 -3 0)
(-39 3 0)
(-39 -3 6)
(-39 3 6)
(153 -3 0)
(153 3 0)
(153 -3 6)
(153 3 6)
(-3 -60 0)
(3 -60 0)
(-3 -60 6)
(3 -60 6)
(-3 60 0)
(3 60 0)
(-3 60 6)
(3 60 6)
(-39 -60 0)
(153 -60 0)
(153 60 0)
(-39 60 0)
(-39 -60 6)
(153 -60 6)
(153 60 6)
(-39 60 6)
(-39 -60 60)
(153 -60 60)
(153 60 60)
(-39 60 60)
(-39 -3 60)
(-39 3 60)
(-3 -60 60)
(3 -60 60)
(153 -3 60)
(153 3 60)
(-3 60 60)
(3 60 60)
(-3 -3 60)
(3 -3 60)
(3 3 60)
(-3 3 60)
blocks
hex (24 16 0 8 28 18 4 10) (36 57 6) simpleGrading (1 1 1)
hex (28 18 4 10 32 38 44 36) (36 57 54) simpleGrading (1 1 1)
hex (16 17 1 0 18 19 5 4) (6 57 6) simpleGrading (1 1 1)
hex (18 19 5 4 38 39 45 44) (6 57 54) simpleGrading (1 1 1)
hex (17 25 12 1 19 29 14 5) (150 57 6) simpleGrading (1 1 1)
hex (19 29 14 5 39 33 40 45) (150 57 54) simpleGrading (1 1 1)
hex (1 12 13 2 5 14 15 6) (150 6 6) simpleGrading (1 1 1)
hex (5 14 15 6 45 40 41 46) (150 6 54) simpleGrading (1 1 1)
hex (2 13 26 21 6 15 30 23) (150 57 6) simpleGrading (1 1 1)
hex (6 15 30 23 46 41 34 43) (150 57 54) simpleGrading (1 1 1)
hex (3 2 21 20 7 6 23 22) (6 57 6) simpleGrading (1 1 1)
hex (7 6 23 22 47 46 43 42) (6 57 54) simpleGrading (1 1 1)
hex (9 3 20 27 11 7 22 31) (36 57 6) simpleGrading (1 1 1)
hex (11 7 22 31 37 47 42 35) (36 57 54) simpleGrading (1 1 1)
hex (8 0 3 9 10 4 7 11) (36 6 6) simpleGrading (1 1 1)
hex (10 4 7 11 36 44 47 37) (36 6 54) simpleGrading (1 1 1)
hex (4 5 6 7 44 45 46 47) (6 6 54) simpleGrading (1 1 1)
hex (0 1 2 3 4 5 6 7) (6 6 6) edgeGrading (1 1 1 1 1 1 1 1 1 1 1 1)
edges
patches
patch inlet
(27 9 11 31)
(37 11 31 35)
(9 8 10 11)
(11 10 36 37)
(8 24 28 10)
(10 28 32 36)
patch outlet
(25 12 14 29)
(29 14 40 33)
(12 13 15 14)
(14 15 41 40)
(13 26 30 15)
(15 30 34 41)
wall front
(0 3 7 4)
wall <back>
(1 2 6 5)
wall <left>
(0 1 5 4)
wall <right>
(2 3 7 6)
wall <top>
(4 5 6 7)
empty <wall>
(24 16 18 28)
(28 18 38 32)
(16 17 19 18)
(18 19 39 38)
(17 25 29 19)
(19 29 33 39)
(26 21 23 30)
(30 23 43 34)
(21 20 22 23)
(23 22 42 43)
(20 27 31 22)
(22 31 35 42)
(32 38 44 36)
(44 36 37 47)
(47 37 35 42)
(38 39 45 44)
(44 45 46 47)
(47 46 43 42)
(39 33 40 45)
(40 45 46 41)
(41 46 43 34)
(16 24 8 0)
(0 8 9 3)
(3 9 27 20)
(17 16 0 1)
(2 3 20 21)
(25 17 1 12)
(12 1 2 13)
(13 2 21 26)
wall <bottom>
(0 1 2 3)
mergePatchPairs
would anyone help me?
ivanyao is offline   Reply With Quote
Old   August 20, 2008, 05:03
Default Run blockMesh with -blockTopol
Mattijs Janssens
mattijs is on a distinguished road
Run blockMesh with -blockTopology option. This will write a .obj file which can be visualised with e.g. javaview or (with objToVTK) with paraview. Both have the option of displaying vertex numbers (with selecting and selection inspector in paraview). Very useful to debug blockMeshes.
mattijs is offline   Reply With Quote
Old   August 20, 2008, 06:39
Default I have written an application
Gavin Tabor
grtabor is on a distinguished road
I have written an application called simpleViewer based on blockMesh, which visualises the block structure of a blockMeshDict file for you. Uses FOX/OpenGL. It works for OF1.4.1; I'm guessing making it work for 1.5 would not be too hard. Email me at g.r.tabor@ex.ac.uk if you would like to try with this.
Gavin
grtabor is offline   Reply With Quote
Old   August 20, 2008, 23:36
Default hi Mattijs, it can't work.whe
weihong yao
hi Mattijs,
it can't work.when i type blockMesh <root> <case> -blockTopology.it show:
#5 main
const IOobject& io,
FOAM aborting
so how do i fix it?
Old   August 21, 2008, 17:21
Default I just went through your block
Mattijs Janssens
I just went through your blockMeshDict. Set all block sizes to (1 1 1) so there are no matching errors. Then commented out all patch specifications (front, back, left, right, top) that give errors. Now with forementioned -blockTopology start putting patches and block sizes back in.
Old   August 22, 2008, 22:35
Default hi, thank you!but now what ca
weihong yao
hi,
thank you!but now what can I do?
Old   August 24, 2008, 22:27
Default hi Mattijs, i am poor in Engl
weihong yao
hi Mattijs,
i am poor in English.so i don't know what to do.
would you tell me the step in detail.please...
How to handle the gcc412 ivanyao OpenFOAM Bugs 1 March 28, 2015 23:35
Is UDF the only way to handle particle melting? marq FLUENT 3 February 23, 2008 02:48
Can CFX handle local hex refinement? JollyP CFX 2 October 31, 2006 10:00
Libstdcso6 cannot handle TLS data barryw OpenFOAM Installation 2 September 7, 2006 03:02
Can ALE handle air bubble breakups? Pei-Ying Hsieh Main CFD Forum 1 May 29, 2003 11:54
