hi guys,
i am using turbfoam,for last one week but always its giving problem. i tried somany times but its giving same problem, can you help me to solve the problem? i have given the problem report Courant Number mean: 1.03295e+09 max: 1.31013e+15 #0 Foam::error::printStack(Foam: ![]() #1 Foam::sigFpe::sigFpeHandler(int) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #2 ?? in "/lib64/libc.so.6" #3 Foam::DILUPreconditioner::calcReciprocalD(Foam::Fi eld<double>&, Foam::lduMatrix const&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #4 Foam::DILUPreconditioner::DILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::Istream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #5 Foam::lduMatrix::preconditioner::addasymMatrixCons tructorToTable<foam::dilupreco nditioner>::New(Foam::lduMatrix::solver const&, Foam::Istream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #6 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::Istream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so" #8 Foam::fvMatrix<foam::vector<double> >::solve(Foam::Istream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/applications/bin/linux64GccDPOpt /turbFoam" #9 main in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/applications/bin/linux64GccDPOpt /turbFoam" #10 __libc_start_main in "/lib64/libc.so.6" #11 Foam::regIOobject::readIfModified() in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/applications/bin/linux64GccDPOpt /turbFoam" regards, sivakumar |
Ivan Lau
Rep Power: 17 ![]() |
Hi, sivakumar,
What is your time step? You need to have small time step when fine grid is used. Do you get this error in the first time step or after few time steps? If it is the first case, you definitely need a smaller time step. Also, try "checkMesh" and see if there is any error. Cheers, iL |
hi thank you for u r replay, deltaT is 0.005
the calculation stoped at 0.145. first time i have given deltaT 0.001 the calculation stoped at 0.085 i think the mesh is ok. the same mesh is working with simpleFoam. now the calculation going on with deltaT is 0.01 0.4 going on can u tell me whats wrong with this? regards, sivakumar |
i am sorry again it stopped working.at 0.05
time step was 0.01 now i have given time step 0.0001 i don't know what will happen. regards, sivakumar |
I think you need to provide additional information on your case study, eg. Reynolds number, boundary conditions, turbulence model, etc. That way it will be easier for people to help you solving your problem. Regards, Jose Santos |
Ivan Lau
Hi, sivakumar,
is it working now? regards, iL |
hi,
till now there is no problem,its going fine. i think i have to wait 3 more days to finish the calculation. i found some mistakes in boundary conditions, but still its working. for example 2 times INLE5, somany times Value(bigletter),value (small letter) is it problem or ok? with regards, sivakumar |
Ivan Lau
Hi, Sivakumar,
Good to hear that it I don't have this problem before, but it should be ok. regards, iL |
HELP NEEDED with TURBFOAM | dinonettis | OpenFOAM Running, Solving & CFD | 64 | June 22, 2010 09:58 |
TurbFoam diverge | ivanyao | OpenFOAM Running, Solving & CFD | 6 | January 11, 2009 07:41 |
Problem with turbFoam | skabilan | OpenFOAM Running, Solving & CFD | 2 | September 29, 2008 17:43 |
TurbFoam | hsieh | OpenFOAM Running, Solving & CFD | 12 | July 23, 2008 07:40 |
Problem about wmake turbFoam | williamscn | OpenFOAM Running, Solving & CFD | 3 | September 19, 2007 11:55 |
