Creating a new case from command line
Like Tree1Likes
Old   October 21, 2008, 05:19
Default Off-hand I know there's an oka
  #21
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Off-hand I know there's an okay example of mis-using an IOMap<dictionary> to write the headers and supply a stream for a Map<dictionary> in src/conversion/meshTables/cellTable.?
Specifically, Foam::cellTable::readDict() and Foam::cellTable::writeDict() might be of some use to you as reference.
BTW: in your original program, you were using include "createMesh.H", but you should be able to just read in the polyMesh/boundary directly (and save lots of time and memory).
Take a look at src/OpenFOAM/meshes/preservePatchTypes/preservePatchTypes.C
olesen is offline   Reply With Quote
Old   October 21, 2008, 07:45
Default Many thanks! I'll have a lo
  #22
Niklas Wikstrom
wikstrom is on a distinguished road
Many thanks!
I'll have a look at it.
/Niklas
wikstrom is offline   Reply With Quote
Old   November 16, 2008, 12:16
Default Hi again, I never had time
  #23
Niklas Wikstrom
Hi again,
I never had time to dive into the dictionary creation and writing inside OF. So, in the mean time I reverted to a simplistic solution and use the following python script to create the changeDictionaryDict:
createChangeDictionaryDict.py
May be useful.
( run with --help :-) )
/N
Old   November 16, 2008, 12:54
Default To explain the previous post:
  #24
Niklas Wikstrom
Using createFieldTemplates (above in this thread) and the python script above,
the procedure I use to initiate fields for a case, after having built the mesh becomes e.g.:
1) createFieldTemplates -scalarFields "(p)" -vectorFields "(U)" -time 3
2) createChangeDictionaryDict.py --fields="U p" --instant=3 -o system/changeDictionaryDict
3) Edit system/changeDictionaryDict
4) changeDictionary -time 3
/N
Old   October 29, 2009, 07:40
Default createFieldTemplates revisited
  #25
Niklas Wikstrom
Uploading a createFieldTemplates that writes a changeDictionaryDict on the fly. Whether you want it or not... Use the -dict option. See description in source header.
/N
Old   November 14, 2013, 08:38
Siemen Dasselaar
Siemen is on a distinguished road
Hi Hakan,
For my centrifugal pump simulations I inject the final solution from a steady-state simulation as initial solution for a transient simulation (using pyFoamCopyLastToFirst.py).
The steady-state simulation computes the flow in a non-rotating impeller inside a volute.
The transient simulation is about an impeller, which is rotating in a volute.
In order to give the rotating impeller the correct boundary conditions, I have to change the type of boundary condition from "fixedValue" to "movingWallVelocity" in the [case/0/U]-file for the transient simulation.
Therefore, I am trying to apply the function <pyFoamCreateBoundaryPatches.py>.
However, it seems that both the type and value of the boundary condition are changed using this function, and I only want to change the type.
Do you know whether it is possible to only change the type and remain the value of the boundary condition unchanged?
Thanks in advance!
Siemen
Siemen is offline   Reply With Quote
restart a case with .trn file in command line way? wayne CFX 0 October 10, 2008 10:02
Command line help Omer CFX 0 August 29, 2008 08:44
Cloning a case or creating a new case for 16 processes mellanoxuser OpenFOAM Running, Solving & CFD 0 February 8, 2008 17:52
Backup from the command line Rui CFX 6 February 22, 2005 11:19
Cloning a case from the command line Daniele Panara (Panara) OpenFOAM Pre-Processing 2 February 1, 2005 10:58
