How to find detail on the spline implementation
Old   March 31, 2005, 04:37
Default Dear all, I need to create
Daniele Panara
panara is on a distinguished road
Dear all,
I need to create a new mesh using splines...
Where I can found the details about the implementation of simpleSpline and polySpline ??
when I use polySpline with the control point that I have I get a segmentation fault.
When I use simpleSpline instead the curve is created but for some reasons even if my interpolation points have x coordinates in the range of my starting and ending point I get a curve with x values outside this range that mess up the grid
Thanks in advance,
Daniele
panara is offline   Reply With Quote
Old   March 31, 2005, 05:03
Default The implementation of splines
henry is on a distinguished road
The implementation of splines in blockMesh is in OpenFOAM-1.1/applications/utilities/mesh/generation/blockMesh/curvedEdges
Unfortunately they haven't been used much and therfore not well tested. Please let us know if you make any improvements to the implementation and it would also be useful to have a few more interesting test meshes using splines that we can distribute with blockMesh.
henry is offline   Reply With Quote
Old   September 15, 2006, 12:51
Default Can you please report a bug fo
Mattijs Janssens
mattijs is on a distinguished road
Can you please report a bug for this?
Thanks
mattijs is offline   Reply With Quote
Old   September 18, 2006, 01:54
Default Will do
olle_bodin
Will do
Old   May 2, 2008, 03:22
Default Can I ask if the polySpline co
Samuel Pang
gemaforce is on a distinguished road
Can I ask if the polySpline command has been fixed for OpenFOAM 1.4.1 already? I have been trying to plot a polySpline, but I'm still getting segmentation errors. And similar to Olle, if it has been changed to polyLine, it works fine. Is there any way I can draw a smooth curve still?
Thanks
Samuel
gemaforce is offline   Reply With Quote
Old   May 2, 2008, 04:22
Default The blockMeshDict posted above
Mattijs Janssens
The blockMeshDict posted above does not contain the start and end point after the control points. (See blockMesh/curvedEdges/polySplineEdge.C where it reads the controlpoints and then two extra points) I have not used splines so cannot help you with their meaning.
Old   July 10, 2008, 11:37
Default Hi, the two vectors at the e
Andrew King
andersking is on a distinguished road
the two vectors at the end of the points list are the starting and ending gradient of the curve. Also, the code has a bug in it (you will always end up with a straight line) The workaround given in the following thread.
http://www.cfd-online.com/OpenFOAM_D.../126/7880.html
Cheers,
Andrew
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
Old   December 3, 2008, 11:47
Default Hallo, the workaround is inte
Wolfgang Heydlauff
wolle1982 will become famous soon enough
Hallo,
the workaround is integrated in OF-1.5. But as I see, it still doesn't work right. Please help on that and see the examplecase in
http://www.cfd-online.com/OpenFOAM_D...6574#POST29425
Thanks.
wolle1982 is offline   Reply With Quote
RhoCentralFoam detail alberto OpenFOAM Running, Solving & CFD 42 January 25, 2024 05:05
how to get the detail information about k-e models limingtiger Siemens 1 July 15, 2005 05:22
tell me the detail step for parallelsolver in cfx4 S. Ding CFX 3 June 14, 2002 14:09
What is the detail definition of wall shear stress zjm FLUENT 0 January 2, 2002 08:43
HVN tell me the detail of relative pressure chong chee nan FLUENT 1 January 2, 2002 05:55
