DieselEngineFoam
Like Tree1Likes
Old   December 3, 2008, 06:54
Default Hi Badiger, you should star
  #41
Markus Rehm
markusrehm is on a distinguished road
Hi Badiger,
you should start with reactingFoam and understand the test case and the solver. Search the Wiki for more information about reactingFoam. The talk I can mail you if you give me your address.
For the inp files: You use a detailed mechanism or a overall one with a hand full of reactions? What kind of combustion is it?
Regards, Markus.
markusrehm is offline   Reply With Quote
Old   December 3, 2008, 23:43
Default thanks for your continuous sup
  #42
Badiger Ramesh
badiger is on a distinguished road
thanks for your continuous support,
I have started with reactingFoam, downloading the case from wiki, also i modified chem.inp with some other fuel name(reaction), but i was not finding the activation energy n other constants for different fuels,
my email-id is rameshbadiger28@gmail.com or rameshbvb@gmail.com
badiger is offline   Reply With Quote
Old   December 3, 2008, 23:53
Default Markus, If you have some te
  #43
Badiger Ramesh
Markus,
If you have some test cases to be solved please give. I ll work with them n send results. Actualy my work here is to implement EDM in OpenFOAM n run some test cases. Then proceed on MultiPhase flows.
So I am reading on combustion and CFD books, If u some good material, Plz guide me
Disable injection in dieselEngineFoam francesco OpenFOAM Running, Solving & CFD 0 November 26, 2008 02:23
Strange pressure with dieselEngineFoam tsencic OpenFOAM Bugs 1 December 12, 2007 05:39
Needing some advise about dieselEngineFoam adorean OpenFOAM Running, Solving & CFD 33 November 20, 2007 00:27
Start with DieselEngineFoam tsencic OpenFOAM Running, Solving & CFD 20 June 28, 2007 22:07
