DieselEngineFoam
Like Tree1Likes
Old   January 13, 2006, 09:52
Default If you havent passsed -66 CAD
  #21
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
If you havent passsed -66 CAD you shouldnt have any combustion yet.
do you have any fuel?
niklas is offline   Reply With Quote
Old   January 13, 2006, 09:56
Default with the wedge geometry I run
  #22
stefan
stefanke is on a distinguished road
with the wedge geometry I run my simulation from -180 to 180 CA. Fuel is also injected and the temperatures are high enough so combustion process should take place!?!
stefanke is offline   Reply With Quote
Old   January 13, 2006, 10:29
Default did you set chemistry on in ch
  #23
niklas's Avatar
Niklas Nordin
did you set chemistry on in chemistryProperties?
If it doesnt burn you reactions are too slow.
That means that its either turned off or
that the reaction rate constant in chem.inp is too low.
Old   January 13, 2006, 10:38
Default Niklas, yes chemistry is on
  #24
stefan
Niklas,
yes chemistry is on!
combustionProperties:
chemistry on;
chemistrySolver ODE;
//chemistrySolver EulerImplicit;
//chemistrySolver sequential;
initialChemicalTimeStep 1.0e-7;
sequentialCoeffs
cTauChem 1.0e-3;
EulerImplicitCoeffs
cTauChem 5.0e-2;
equilibriumRateLimiter off;
ODECoeffs
ODESolver SIBS;
eps 5.0e-2;
scale 1.0;
I tried the the single step mechanism (chem.inp1) and chem.inp_15 delivered from the dieselFoam tutorial. I think the reation rates of this schemes should be ok or not?
Old   January 16, 2007, 06:42
Default Hi,everyone Now I try to se
  #25
atsushi
Hi,everyone
Now I try to setup dieselEngineFoam.
It seems that there is no definition about injection timing in dieselFoam.
Where and How should I define it?
Old   January 16, 2007, 06:46
  #26
atsushi
Hi,everyone
Old   May 17, 2007, 03:07
Default Is there anybody who can help
  #27
atsushi
Is there anybody who can help me ??
Atsushi
Old   June 18, 2007, 00:22
Default I run dieselEngineFoam of OF 1
  #28
nishio
I run dieselEngineFoam of OF 1.3.
I got this error message.
--> FOAM FATAL IO ERROR : keyword cyclics is undefined in dictionary "/home/nishio/OpenFOAM/nishio-1.3/run/tutorials/dieselEngineFoam14/cyclic_test/- 180/p::boundaryField"
file: /home/nishio/OpenFOAM/nishio-1.3/run/tutorials/dieselEngineFoam14/cyclic_test/-1 80/p::boundaryField from line 31 to line 45.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 152.
this is dieselEngineFoam/test/-180/p.
dimensions [ 1 -1 -2 0 0 0 0 ];
internalField uniform 100000;
boundaryField
piston
type zeroGradient;
liner
type zeroGradient;
cylinderHead
type zeroGradient;
cyclics...
type zeroGradient;
What is wrong?
Please tell me.
thanks.
Old   June 18, 2007, 00:31
Default You have either messed up the
  #29
Hrvoje Jasak
You have either messed up the brackets or have hidden Microsoft endline characters (Ctrl-M) in the bit which says
cylinderHead
type zeroGradient;
cyclics...
type zeroGradient;
By the way, what are those dots after "cyclics"?
As a consequence, the solver cannot find the bit that says "cyclics" to locate the subdictionary.
There may be other things wrong as well, e.g. the boundary condition type on the cyclic boundary should be "cyclic", but the code will tell you what it thinks.
Good luck,
Hrv
Hrvoje Jasak
Old   June 29, 2007, 06:31
Default I run dieselEngineFoam of tuto
  #30
nishio
I run dieselEngineFoam of tutorials.
Below,I show log dieselEngineFoam.
No Iterations of rho is 0. what happen?
Why this result occured?
Please teach me.
thanks.
Number of parcels in system | 2441
Injected liquid mass....... | 0.585093 mg
Liquid Mass in system...... | 0.556518 mg
SMD, Dmax.................. | 8.04166 mu, 144.482 mu
Added gas mass = 0.0285751 mg
Evaporation Continuity Error| -1.50067e-09 mg
ExecutionTime = 1403.97 s ClockTime = 1405 s
Mean and max Courant Numbers = 6.06171e-05 0.0998279
deltaT = 4.11218e-08
Crank angle = -14.8499 CA-deg
deltaZ = 8.26244e-08
clearance: 0.00709141
Piston speed = 2.00926 m/s
Solving chemistry
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterati
ons 0
BICCG: Solving for Ux, Initial residual = 0.00112271, Final residual = 6.95297e
-08, No Iterations 1
BICCG: Solving for Uy, Initial residual = 0.00110164, Final residual = 8.77127e
-07, No Iterations 1
BICCG: Solving for Uz, Initial residual = 0.00131305, Final residual = 2.67449e
BICCG: Solving for C7H16, Initial residual = 0.00252406, Final residual = 3.952
72e-07, No Iterations 1
BICCG: Solving for O2, Initial residual = 0.00218811, Final residual = 3.20441e
BICCG: Solving for CO2, Initial residual = 0.00116516, Final residual = 1.68511
BICCG: Solving for H2O, Initial residual = 0.00116516, Final residual = 1.68511
BICCG: Solving for h, Initial residual = 0.000129235, Final residual = 2.90022e
ICCG: Solving for p, Initial residual = 0.0204819, Final residual = 3.29525e-13
, No Iterations 2
ons 0
time step continuity errors : sum local = 3.65186e-16, global = 2.63727e-16, cum
ulative = 4.27066e-12
ICCG: Solving for p, Initial residual = 8.59685e-05, Final residual = 2.52916e-
10, No Iterations 1
ons 0
time step continuity errors : sum local = 2.56815e-13, global = 7.56819e-15, cum
ulative = 4.27823e-12
BICCG: Solving for epsilon, Initial residual = 0.000555864, Final residual = 6.
98831e-08, No Iterations 1
BICCG: Solving for k, Initial residual = 0.000689, Final residual = 1.17105e-07
, No Iterations 1
Mean pressure:3.45583e+06
Mean temperature:914.791
Mean u':2.51441
Old   July 19, 2007, 05:32
Default Hello, I try to setup diese
  #31
tanaka
Now I don't understand amethod to "merge" the two cases to get a setup for the dieselEngine solver.
I want you to teach it in detail.
Thanks if you can help.
tanaka
Old   July 20, 2007, 04:08
Default Hi Tanaka, You should check
  #32
atsushi
Hi Tanaka,
You should check old log
In Preprocessing/FoamX/dieselEngineFoam
Good luck!
Atsushi
Old   July 26, 2007, 09:17
Default Atsushi, Thanks a lot for y
  #33
tanaka
Atsushi,
Thanks a lot for your help.
It's now working!
Old   September 3, 2007, 03:30
Default Hi, "0" folder in dieselFoa
  #34
atsushi
"0" folder in dieselFoam ,
I can see "N2:0.766, O2:0.233" composition.
What kind of fraction?
Volume fraction or mass fraction?
Thanks.
Atsushi
Old   September 4, 2007, 12:10
Default mass fraction. the solvers di
  #35
frackowi
mass fraction.
the solvers dieselFoam use it in the equations:
in createFields.
Hfor(label i=0; i<Y.size(); i++)
fields.add(Y[i]);
in Yeqn
solve
fvm::ddt(rho, Yi)
+ mvConvection->fvmDiv(phi, Yi)
- fvm::laplacian(turbulence->muEff(), Yi)
== kappa*chemistry.RR(i),
mesh.solver("Yi")
which is the mass conservation equation for a specie i, implying mass fraction Yi
Bruno
amolrajan likes this.
Old   September 5, 2007, 05:47
Default Bruno, Thanks for your quic
  #36
atsushi
Bruno,
Thanks for your quick answer!
Atsu
Old   November 25, 2007, 08:38
Default Hello, I want to know Reyno
  #37
atsushi
I want to know Reynolds number "Re" and viscosity "&mu;" of some cells per CA.
I found "sampleDict" in stressedFoam/plateHole/system.
Can I check "Re" and "&mu;" in dieselEngineFoam using sampleDict?
Thanks.
Atsu
Old   November 24, 2008, 09:01
Default Hello Sir, I am new OpenFOAM,
  #38
Badiger Ramesh
badiger is on a distinguished road
Hello Sir,
I am new OpenFOAM,
I am trying to implementing Eddy Dissipation Concept, Can any body tell whether it is already there in OpenFOAM-1.5 or still to be implemented,
And give me some guidelines to set up a basic combustion problem in OpenFOAM
badiger is offline   Reply With Quote
Old   November 25, 2008, 09:22
Default Hello Badiger, I implemente
  #39
Markus Rehm
markusrehm is on a distinguished road
Hello Badiger,
I implemented it and have done a few test calculations but still it is not in a condition to be published. I hope to do that in a few weeks.
I showed it at the Workshop in Milan this year. If you want to I can send you the slides.
Regards, Markus.
markusrehm is offline   Reply With Quote
Old   December 3, 2008, 03:25
Default Thanks Markus, Please send,
  #40
Badiger Ramesh
Thanks Markus,
Please send, I ll go through,
Can you guide me in implementing a combustion problm, a simple one, some start ups i have already started with it, but stucking in writing chem.inp file requiring values of Activation energy etc.. for different fuels
Plz do the needful
Disable injection in dieselEngineFoam francesco OpenFOAM Running, Solving & CFD 0 November 26, 2008 02:23
Strange pressure with dieselEngineFoam tsencic OpenFOAM Bugs 1 December 12, 2007 05:39
Needing some advise about dieselEngineFoam adorean OpenFOAM Running, Solving & CFD 33 November 20, 2007 00:27
Start with DieselEngineFoam tsencic OpenFOAM Running, Solving & CFD 20 June 28, 2007 22:07
