Wall contact angle
Old   January 28, 2009, 14:34
Default Hello, I working with inter
Eelco Gehring
feijooos is on a distinguished road
I working with interFoam and I am trying to specify a specific contact angle for the fluid, in this case water. I searched the forum for related topics. I found a couple, but I can't seem to get it to work.
How do I implement the constantGammaContactAngle?
I know I have to specify it in my gamma field (/0/gamma). However, when I do this, I get an error upon using the setFields utility. It tells me that the gamma field is not found, wrong token word.
Can somebody help me out?
Thanks,
Eelco
feijooos is offline   Reply With Quote
Old   February 2, 2009, 02:43
Default anybody?
Eelco Gehring
anybody?
Old   February 2, 2009, 08:44
Default Hello Eelco, Pl. try using
vof_user
asaha is on a distinguished road
Hello Eelco,
Pl. try using constantGammaContactAngle in damBreak tutorial as below:
boundaryField
leftWall
type constantGammaContactAngle;
theta0 40;
uTheta 0;
thetaA 40;
thetaR 40;
value uniform 0;
rightWall
theta0 40;
uTheta 0;
thetaA 40;
thetaR 40;
value uniform 0;
lowerWall
theta0 40;
uTheta 0;
thetaA 40;
thetaR 40;
value uniform 0;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
defaultFaces
type empty;
Regards,
a a saha.
asaha is offline   Reply With Quote
Old   February 2, 2009, 11:36
Default Hi a a saha, Thanks for you
Eelco Gehring
Hi a a saha,
Thanks for your reply. I tried it out in the dambreak case and it is working. However, when I try implementing it in a 3D case it does not work. When I run the setFields command to initialize the gamma field, nothing happens. SetFields runs fine, but the gamma file (/0/gamma) doesn't get initialized. Any ideas?
Thanks,
Eelco
Old   February 3, 2009, 12:52
Default I think I solved the problem.
Eelco Gehring
I think I solved the problem. Setfields doesn't work, but funkySetFields does if I use the -keepPatches option. Seems to be working fine now.
Thanks for the help. Eelco
How to vary wall contact angle in the solver hsieh OpenFOAM Running, Solving & CFD 8 June 11, 2024 09:37
contact angle yan FLUENT 4 November 6, 2012 05:22
Wall contact angle feijooos OpenFOAM Pre-Processing 0 January 28, 2009 14:31
Moving contact line (dynamic contact angle) Pulli FLUENT 0 March 1, 2007 13:31
how to code wall contact angle? schou Main CFD Forum 2 May 5, 2003 21:50
