Is there a simple way to make refineMesh write the cellLevel |
Christian Trapp
Rep Power: 17 ![]() |
Hello.
Right now I'm working on a tool that does multiple runs of refineMesh and modifies the refineMeshDict according to a new dictionary (refineRegionsDict) before each run. To keep the meshes cheap I have integrated an option to make sure that already refined cells (from snappyHexMesh) are deleted from the selected region. To achieve this, the case is copied to a backup and mapFields is used after each step to refresh the cellLevel. This works fine to avoid the cells that have been refined by snappyHexMesh but does not get the ones that resultet from running refineMesh. So, does anybody know a way to get refineMesh to write the cellLevel? With kind regards, Christian. |
[mesh manipulation] BlockMesh cellSet refineMesh | mattijs | OpenFOAM Meshing & Mesh Conversion | 41 | April 7, 2020 09:32 |
[mesh manipulation] RefineMesh tetrahedral | markc | OpenFOAM Meshing & Mesh Conversion | 3 | December 7, 2010 09:16 |
[blockMesh] RefineMesh warning | mgz1985 | OpenFOAM Meshing & Mesh Conversion | 1 | August 29, 2008 08:45 |
[mesh manipulation] Using refineMesh | matteo_gautero | OpenFOAM Meshing & Mesh Conversion | 0 | February 11, 2008 09:07 |
How to write a simple program ?? | kokey | FLUENT | 0 | March 19, 2002 10:21 |
