DirectionMixed mixed bc
Like Tree78Likes
Old   November 7, 2013, 00:55
Srivathsan N
Sherlock_1812 is on a distinguished road
Hi Philip,
I have been trying to re-write valueFraction for each face of my patch as symm(n*n). I have a very basic doubt.
Is it better to write a new BC (derived from directionMixed (maybe?)) where this definition of valueFraction is changed as symm(n*n) while looping over all faces of the patch? If yes, where do I make the changes? In the 'updateCoeffs' section?
Thanks.
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   September 15, 2014, 12:28
Sliwa is on a distinguished road
Originally Posted by hjasak View Post
4) If this is not enough for you (there is another possibility), I have written a newDirectionMixedFvPatchField boundary condition, with 4 components. Unlike the above one, this b.c. allows both the normal and tangential condition to be mixed separately between the fixedValue and fixedGradient b.c. with two blending factors. You need this kind of thing for contact problems with friction and large deformation and similar. In my version, the stuff lives in:
OpenFOAM-1.2/applications/solvers/newStressAnalysis/materialModels/newDirectionM ixed
In my problem, I would like to specify on one of my boundaries:
- a zero gradient for the normal component of the displacement
- a zero displacement in the tangential direction
The newDirectionMixed looked like the perfect solution. However, when I ran it with my solver, I got the following error:
--> FOAM FATAL IO ERROR:
    Cannot find 'value' entry on patch symr of field U in file "/home/salwa/OpenFOAM/salwa-extend-3.0/run/tutorials/solidMechanics/elasticThermalSolidFoam/flosse_test1/0/U"
    which is required to set the values of the generic patch field.
    (Actual type newDirectionMixed)
    Please add the 'value' entry to the write function of the user-defined boundary-condition
    or link the boundary-condition into libfoamUtil.so
file: /home/salwa/OpenFOAM/salwa-extend-3.0/run/tutorials/solidMechanics/elasticThermalSolidFoam/flosse_test1/0/U::boundaryField::symr from line 64 to line 69.
    From function genericFvPatchField<Type>::genericFvPatchField(const fvPatch&, const Field<Type>&, const dictionary&)
    in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 71.
FOAM exiting
Adding a 'value' entry gave this error:
gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type newDirectionMixed)
    You are probably trying to solve for a field with a generic boundary condition.
    From function genericFvPatchField<Type>::gradientInternalCoeffs() const
    in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 811.
FOAM exiting
This is my U file:
symr
        type                                newDirectionMixed;
        refValue                           uniform    0;
        refGrad                            uniform    0;
        nHat                               (1 0 0);
        normalValueFraction            0;
        tangentialValueFraction       1;
        value                               uniform (0 0 0);
Does anyone know where the problem might come from? Is there something wrong with my U file?
Thanks,
Sliwa is offline   Reply With Quote
Old   September 17, 2014, 11:02
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Sliwa,
directionMixed can do this: the capabilities of newDirectionMixed have essentially been included in the current directionMixed boundary condition, as valueFraction is a symmTensor now instead of a scalar.
To achieve what you want, use directionMixed like this:
myPatch
    type              directionMixed;
    refValue          uniform ( 0 0 0 );
    refGradient       uniform ( 0 0 0 );
    valueFraction     uniform ( 0 0 0 1 0 1 ); // (I - sqr(n))
    value             uniform ( 0 0 0 );
where I have assumed n = ( 1 0 0 ) above.
You can see that to fix the value in the normal direction valueFraction = sqr(n), whereas to fix the value in the tangential directions valueFraction = I - sqr(n).
Best regards,
Philip
tom ato and meth like this.
bigphil is offline   Reply With Quote
Old   September 17, 2014, 11:03
bigphil's Avatar
Philip Cardiff
Originally Posted by Sherlock_1812 View Post
Hi Philip,
Thanks.
Hi Srivaths,
yes you should derive a new boundary condition from directionMixed and set the valueFraction in the constructor or, if the mesh is moving/changing, in updateCoeffs.
See for example, fixedDisplacementZeroShear in $FOAM_SRC/solidModels.fvPatchVectorFields in foam extend.
Best regards,
Philip
Old   September 18, 2014, 11:55
Thank you, Philip! That worked.
Old   August 9, 2015, 22:10
Amir
infinity is on a distinguished road
Hi Dear Foamers
I'm trying to use no-stress wall boundary condition
and I used:
        refValue        uniform (0 0 0);
        refGradient     uniform (0 0 0);
        valueFraction   uniform (0 0 0 1 0 0);
and now I'm getting wrong answers
I would appreciate if anyone could help me
infinity is offline   Reply With Quote
Old   August 12, 2015, 12:09
Amir
any answer guys ?
Old   August 12, 2015, 12:13
bigphil's Avatar
Philip Cardiff
I think the slip boundary condition already does what you want.
See here.
Philip
Old   August 12, 2015, 12:48
Amir
Thanks a lot Philip
It was very Helpful
Old   December 3, 2015, 19:02
Saurabh Tandon
STutexas is on a distinguished road
Originally Posted by bigphil View Post
Hi Nicolas,
Yes it is possible, using directionMixed, to give every face on a boundary patch a different gradient in the tangential direction. I would do something like this in a header file at the start of a time-step (although it might be possible to use groovyBC but I am not sure):
label patchID = mesh.boundaryMesh().findPatchID("patchOfInterest");
if(patchID == -1)
    Info << "patch not found" << endl;
    return 0;
directionMixedFvPatchVectorField& Upatch =
        refCast<directionMixedFvPatchVectorField>
         U.boundaryField()[patchID]
//- patch face normals
vectorField n = mesh.boundary()[loadingIndex].nf();
//- set value fraction so as to have fixed value in patch normal direction
Upatch.valueFraction() = symm(n*n);
//- set fixed value
Upatch.refValue() = vector (0, 0, 0); //- put what ever vectorField you want here
//- set fixed gradient (as a function of position and time as an example)
const vectorField& patchFaceCentres = mesh.boundaryMesh()[patchID].faceCentre();
Upatch.refGradient() = patchFaceCentres * runTime.value();
By the way, "U" is my solution variable above.
Hope this helps,
Philip
Hi Philip
Interesting explanation for the changing the refGradient in the directionMixed BC. If we include this code in the data can we give any values in directionMixed condition in the 0/U file? Is it possible to set a nonuniform value for the valuefraction in a similar manner using tensor fields.
Thank you.
Saurabh
STutexas is offline   Reply With Quote
Old   December 3, 2015, 19:07
Saurabh Tandon
Hi Philip
Just another doubt. Can we use funkySetFields with directionMixed BC. I am getting an error when I try to do that. This is the error:
"ill defined primitiveEntry starting at keyword 'valueFraction' on line 29 and ending at line 41"
Thank you.
Old   December 4, 2015, 20:40
Default Yes you can code with C++ many great thing in OF
  #52
nlc
nlc's Avatar
Nicolas Lussier Clément
nlc is on a distinguished road
Yes Saurabh you can do this,
If you want to this you want to define a summetric tensor field as a variable initialize it corectly with all the constructors and add it to the maping function if you want to be able to use it in parallèle.
You can always look at boundary condition source code to give you great exemple, ther is plenty of them.
But valueFraction is alrethy a symmTensorField !?? I'm not shure what is your objectif in creating your new dirrectionMixed boundary condition.
I dont konw about funkysetfield I did not use it yet.
Out of curiosity why do you want to do this ? What are you tring to accomplish ?
Not shur what you mean by including the code in the data ?
Hope this was usfull
nlc is offline   Reply With Quote
Old   December 4, 2015, 22:09
Saurabh Tandon
[QUOTE=ubald;576267]Yes Saurabh you can do this,
Hi Nicolas
Thank you for replying so quickly. I will take a look the deifnition of the codes and see if I can compile my own BC. I am trying to use openFoam for magnetic decay simulations and my BC doesnot have a symm tensor in value fraction. Please peruse my post:
http://www.cfd-online.com/Forums/ope...groovy-bc.html
This might give you more context to what I am trying to do. Thanks again for the help.
Old   October 20, 2016, 01:36
Default directionMixed for fluid-fluid interface
  #54
Praveen Srikanth
praveensrikanth91 is on a distinguished road
I am trying to use the conjugate heat transfer solver to compute phase change at a liquid-vapor interface. I have implemented the phase change models into the solver with just a normal velocity at the interface for the phase change. However, I have vapor flow over the interface which would create a viscous shear on the surface of the liquid. The boundary condition for the problem is essentially equal tangential velocities on either side of the interface and equal tangential shear stresses. Added to this is the fixed value in the normal direction. I was thinking that this would be possible to be implemented using the directionMixed boundary condition. However I am not sure how the value fraction would look for such a scenario.
Is it possible to use directionMixed for such a BC? I am hoping someone with some experience would be able to direct me in the right direction. As far as I know there does not seem to be any similar boundary conditions in OF.
Thanks so much for your time
Praveen
praveensrikanth91 is offline   Reply With Quote
Old   November 17, 2017, 14:24
behzad Ghasemi
behzad-cfd is on a distinguished road
I don't know i'm in right thread or not by the way I want to solve equation and obtain B that is defined like .
I've implemented the equation in my base solver. Now i want to test functionality of the new solver but i have some boundary condition problem before testing.
For example if i want to get in boundaries i need to set and .
Can i use directionMixed BC for this?
How can i implement this BCs?
Thanks in advance,
Behzad
behzad-cfd is offline   Reply With Quote
Old   November 18, 2017, 20:16
Default I think it is better to start a new tread
  #56
nlc
nlc's Avatar
Hi Behzad,
OpenFOAM is 3D by défaut 1D and 2D case are achieve by setting special BC. The equations you share seem to be 2D. You need first to specify your equations in 3D then figure ought what type of BC you need. Fixed, gradient, mixed !! Then you'll know what to look for.
It seems to me that you should start a new thread. Wright the hole set of equations for your problem with detail on the boundary condition you want to use. Or a link in an article relevant to your case.
It is better to use vector notation then component details as OF use vector and tensor notation. Add me on your new tread please as it seems interesting.
NLC
Old   November 18, 2017, 20:36
behzad Ghasemi
Originally Posted by nlc View Post
Hi Behzad,
OpenFOAM je 3D n'y défaut 1D and 2D case are achieve by setting special BC. The equation you share seem to be 2D. You need first to specify your equation on 3D then figure ought what type of BC you need. Fixed, gradient, mixed !! Then you'll know what to look for.
NLC
Hi Nicolas,
Thanks for kind reply. as you mentioned OF operates in 3D my case is 2D and I'll set front and back plane as empty and that's not the problem. I showed component details for clarifying the variable relations and boundary conditions. any way I'll open new thread and add you there.
Kind regards,
Behzad
Old   November 19, 2017, 07:25
behzad Ghasemi
Originally Posted by behzad-cfd View Post
Hi Nicolas,
Kind regards,
Behzad
Hi Nicolas,
This is the link of new thread.
https://www.cfd-online.com/Forums/op...tml#post671506
Old   January 11, 2019, 12:32
Default spatially varying mixed boundary condition
  #59
Nilay Kulkarni
neilk is on a distinguished road
I have a doubt regarding mixed boundary condition. The available mixedFvPatchField I have to specify fixed Value and a normal gradient. I want to apply a mixed BC to a wall to simulate mass diffusion across it. Thus boundary condition to vary along the wall for varying mass fraction gradients and mass fraction values in cells neighboring the wall. Is there a boundary condition that provides this facility? I have attached the boundary condition equation below where Cmucus is the mass concentration which undergoes convection-diffusion and the coefficients of Cmucus are constants.
Thank you
neilk is offline   Reply With Quote
Old   June 11, 2019, 05:35
Pavithra is on a distinguished road
Hello Everyone
I am unable to understand the mixed boundary condition clearly.
I have a vertical wall and I want to set the x-component of velocity to be u = 0 and y-component of velocity to be set as dv/dx = 0.
In order to achieve this, I have implemented the following
sideWall
valueFraction uniform (0 0 0 0 0 1);
but, when I plot I see non-zero values for the x-component.
Kindly, please help me.
With Thanks & Regards,
Pavithra.
Pavithra is offline   Reply With Quote
mixed difference Shuo Main CFD Forum 1 September 3, 2008 02:25
mixed convection sumesh FLUENT 0 March 7, 2008 01:00
Mixed CPU/GPU computing Joe Main CFD Forum 4 September 20, 2006 13:04
Direction mixed bc evgenii OpenFOAM Pre-Processing 1 November 30, 2005 05:37
mixed convection raj calay Main CFD Forum 6 April 21, 1999 23:33
