October 20, 2011, 11:06 |
#21 |
Philip Cardiff
Rep Power: 34 |
Nicolas,
I am not too familiar with writing a boundary condition but I think you can call the mother constructor to set gradients etc (see $FOAM_SOLVERS/newStressAnalysis/materialModels/fvPatchFields/tractionDisplacement/tractionDisplacementFvPatchVectorField.C in OpenFOAM-1.6-ext which is derived from fixedGradient). Philip |
October 20, 2011, 11:35 |
#22 |
Nicolas Lussier Clément
Rep Power: 17 |
Great example Tanks
February 5, 2012, 09:35 |
#23 |
Robert Sawko
Rep Power: 22 |
I would like to implement Newton's law of cooling. This is a type of Robin boundary condition, which is specified by
\frac{\partial T}{\partial n} = -(h A/k) (T_w - T_{ref}) where h, A, k are problem constants, n is the normal to the boundary and T is the temperature. The subscript w, means wall temperature and ref is the reference ambient temperature. I would be happy to implement and test this, but I would need to understand the code a little bit more. Can mixed boundary condition simulate that kind of behaviour? Essentially I would like to have a basic BC that allows to specify a b and g as described here: http://en.wikipedia.org/wiki/Robin_boundary_condition I would be obliged for any hints. |
February 5, 2012, 10:47 |
#24 |
Robert Sawko
Rep Power: 22 |
Right... I think I've answered my questions now, although as a "home-grown" user and programmer of OF I will always appreciate any help and comments.
After analysis of the code in fixedGradient, fixedValue and mixed, I came to a conclusion that for my BC I need to express the functions snGrad and evaluate. One way to do it, is
Is there anything else I should keep in mind? I don't quite understand what's the purpose of XCoeffs functions. Do I need to make alterations there as well? Is it off-topic? Should I post in developers forum? |
February 5, 2012, 16:47 |
#25 |
Hi Robert,
an explanation how to use modified mixed BC for your equation see the post http://www.cfd-online.com/Forums/ope...tml#post295694
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
February 5, 2012, 19:37 |
#26 |
Robert Sawko
Rep Power: 22 |
Thank you very much for the reply. Yes, I was actually thinking of expressing the equations in terms of the blending coefficient, but for some reason I thought it will not be possible. Clearly, I was wrong.
Incidentally, I've written my version of robinBC which evaluates the face value in exactly the same way. It calculates the gradient in a similar manner. It is a 1st order approximation. However, I have not touched XCoeff functions as I am still not sure what they do and my robinBC is not tested. The only positive is that it doesn't diverge when I run it with my case. Now I could test it against this setting of mixed BC. Many thanks. |
February 5, 2012, 19:42 |
#27 |
The XCoeff (nice name:-)) functions update your diagonal elements of the linear system which you solve after all based on the BC type. And it uses either your value representation at the boundary for let's say convectional terms or gradient treatment for your diffusion terms.
February 6, 2012, 06:55 |
#28 |
Robert Sawko
Rep Power: 22 |
Thanks again. The main advantage of my implementation, if it proves to work, should be an easier definition of the transfer coefficient. The mixed BC "hack" requires to specify delta which is the first cell centroid wall distance. I would like to get rid of that!
June 18, 2012, 14:21 |
hi
#29 |
moon
Rep Power: 14 |
how about mixed boundary condition in FLUENT code ,please ?
thank you |
July 31, 2012, 12:56 |
#30 |
Mieszko Młody
Rep Power: 17 |
Dear Bigphil
I tried your method to customize directionMixed BC but I could not compile my code. I got following errors: error: ‘directionMixedFvPatchVectorField’ was not declared in this scope error: ‘loadingIndex’ was not declared in this scope error: ‘const class Foam:olyPatch’ has no member named ‘faceCentre’ Do you know maybe what can be reason for that ? Currently I am using 2.1.0 OpenFOAM. Do you know maybe if it is possible to use groovyBC it this case ? Best and thank you ZM |
July 31, 2012, 13:03 |
#31 |
Mieszko Młody
Rep Power: 17 |
Dear Bigphil
I tried your method to customize directionMixed BC but I could not compile my code. I got following errors: error: ‘directionMixedFvPatchVectorField’ was not declared in this scope error: ‘loadingIndex’ was not declared in this scope error: ‘const class FoamolyPatch’ has no member named ‘faceCentre’ Do you know maybe what can be reason for that ? Currently I am using 2.1.0 OpenFOAM. Do you know maybe if it is possible to use groovyBC it this case ? Best and thank you ZM |
July 31, 2012, 13:07 |
#32 |
Philip Cardiff
Rep Power: 34 |
Hi ZM,
Actually there is a small mistake in my previous code snippet: this line: Code:
vectorField n = mesh.boundary()[loadingIndex].nf(); Code:
vectorField n = mesh.boundary()[patchID].nf(); Code:
const vectorField& patchFaceCentres = mesh.boundaryMesh()[patchID].faceCentre(); Code:
const vectorField& patchFaceCentres = mesh.boundaryMesh()[patchID].faceCentres(); Code:
#include "directionMixedFvPatchFields.H" |
July 31, 2012, 13:31 |
#33 |
Mieszko Młody
Rep Power: 17 |
Hi Philip
Thanks a lot ! There is one more error: error: ‘Foam::directionMixedFvPatchVectorField’ has no member named ‘refGradient’ but I corrected it: instead: Upatch.refGradient() = patchFaceCentres * runTime.value(); should be: Upatch.refGrad() = patchFaceCentres * runTime.value(); Thanks again -ZM |
July 31, 2012, 13:39 |
#34 |
Philip Cardiff
Rep Power: 34 |
Great,
hopefully it'll do what you want. In answer to your earlier question, I would say that groovy/swak4Foam can more than likely do what you want also, but I have never used it. Philip |
September 17, 2013, 06:59 |
#35 |
Srivathsan N
Rep Power: 13 |
Greetings.
I have got a fairly clear idea about directionMixed Bc from this thread. Thank you! I have one question though (may be trivial, but still). What are the three components of the vector given as input to refGradient in cartesian notations? Example, if refGradient is (-1 0 0) is dv1/dx= -1 or dv1/dz? How does one assign partial du/dy and/or partial dv/dx alone using this bc?
Regards, Srivaths Last edited by Sherlock_1812; September 18, 2013 at 06:52. |
September 18, 2013, 07:59 |
#36 | |
Philip Cardiff
Rep Power: 34 |
refGradient is (-1 0 0) means: dvx/dn = -1 dvy/dn = 0 dvz/dn = 0 where vx, vy, vz are the cartesian components of vector field v (e.g. velocity) and n is the patch normal direction. Keep in mind, the valueFraction will control the fraction of the refValue used and the fraction of the refGradient used. Philip |
September 18, 2013, 08:06 |
#37 |
Srivathsan N
Rep Power: 13 |
Thank you Philip!
Regards, Srivaths |
September 18, 2013, 14:07 |
#38 | |
Srivathsan N
Rep Power: 13 |
I'm not able to understand what changes are to be made to valueFraction in the above case (using refCast?). I have a curved patch where face normals are different for different faces, so I see that I should do what you've said. My C++ isn't that good. Can you elaborate? If two faces in a patch have different normals n1 and n2, then the valueFraction is given by symm(n1*n2)? Is this right? Thanks in advance,
Regards, Srivaths |
September 19, 2013, 06:11 |
#39 | |
Philip Cardiff
Rep Power: 34 |
in the case where you would like the normal component to be fixedValue and the tangential components to be fixedGradient then you fix the face valueFraction to be symm(n*n) where n is the face normal. e.g. if you have a list of faces (f1, f2, f3, …) with face normals (n1, n2, n3, …) then you would set the valueFractions to be symm(n1*n1), symm(n2*n2), symm(n3*n3), … Philip |
September 19, 2013, 07:51 |
#40 |
Srivathsan N
Rep Power: 13 |
Thank you for your quick reply Philip
Regards, Srivaths |
mixed difference | Shuo | Main CFD Forum | 1 | September 3, 2008 02:25 |
mixed convection | sumesh | FLUENT | 0 | March 7, 2008 01:00 |
Mixed CPU/GPU computing | Joe | Main CFD Forum | 4 | September 20, 2006 13:04 |
Direction mixed bc | evgenii | OpenFOAM Pre-Processing | 1 | November 30, 2005 05:37 |
mixed convection | raj calay | Main CFD Forum | 6 | April 21, 1999 23:33 |
