Parallel case setup boundry conditions snappyhexmesh
Old   March 8, 2009, 19:39
Default I've probably been going at th
Oskar
oskar is on a distinguished road
I've probably been going at this the wrong way, but haven't been able to find the correct way to to setup a parallel case.
What I've been doing:
1. blockMesh
2. snappyHexMesh
3. manually define boundary conditions
4. decomposePar
5. mpirun case
I would prefer to run snappyHexMesh in parallel because:
a) running out of memory on single computer
b) running on one core is very slow
What I've tried:
1. manually setup boundary condition for time 0
2. decomposeParDict: method metis
3. blockMesh
4. decomposePar
5. decomposeParDict: method parMetis
6. mpirun snappyHexMesh
This results in a good mesh, but the problem is I can't figure out how to get the boundary conditions to follow the mesh generation to timestep 3. Snappyhexmesh does insert the stl-wall boundary correctly, but doesn't touch the p, U etc. files.
Could some knowledgeable FOAMer point me in the right direction?
oskar is offline   Reply With Quote
Old   April 15, 2009, 15:04
Oskar
Surely someone must have a elegant way to setup the initial field for parallel cases while using snappyHexMesh in parallel?
How do you do it?
I tried using mapFields, but I couldn't figure out a way to setup the case using the "-consistent" flag (since the stl-surface isn't there before running snappyHexMesh). Without the -consistent flag mapFields requires the "destination" case to already have the field variables set to something. Creating the field variable in the first place is what I'm trying to do!
Manually setting the initial field variables isn't very efficient since a lot of files need to be created (or copied and tweaked individually). Especially if batch runs with small adjustments need to be run this is impossible to do without a tool.
Using a CFD program with no user interface seems to be very difficult.
Old   April 16, 2009, 12:23
Francesco Del Citto
fra76 is on a distinguished road
I don't know if it works for parallel cases as well, but have you tried pyFoam? Search the forum for it.
Francesco
fra76 is offline   Reply With Quote
Old   April 17, 2009, 08:34
Oskar
Thanks for the tip fra76!
I found some documentation to pyFoam on openfoamwiki.net, looks to have useful tools.
I also stumbled across funkySetFields, tried that out and it's somewhat capable of doing what I what with a single command. (for parallel case setups needs to be run with the same processor amount as the case is decomposed to though)
mpirun -hostfile ~/foamHosts funkySetFields -create -field U -expression 'vector(60,0,0)' -time 3 -parallel
I'll probably have to learn how to make the hideously cryptic bash scripts, but funkySetFields seems to be able to do most of what I what so hopefully I wont need to figure that much out.
Old   September 9, 2009, 07:20
Andrew King
andersking is on a distinguished road
Hi Oscar,
see
http://www.cfd-online.com/Forums/ope...tml#post228991
I have a feeling this may work (testing at the moment)
Cheers
Andrew
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
Old   September 11, 2009, 02:12
Cem Albukrek
albcem is on a distinguished road
I had the exact same problem as the original poster. I have not found an elegant way, but use a rather convenient work around:
  1. Reconstruct your decomposed mesh output by snappyhexmesh
  2. Transfer the reconstructed mesh to the appropriate location in constant/ directory
  3. Set fields serially
  4. Re-decompose
Note that none of the above steps seem to consume the memory associated with the whole mesh, so you should be able to build your case without problems.
albcem is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh in 2D case sjs OpenFOAM Meshing & Mesh Conversion 12 November 8, 2019 05:51
boundry conditions pardeep kumar FLUENT 1 February 15, 2009 13:30
Boundry conditions!!!! Zaher CFX 2 March 16, 2004 10:25
Boundry Conditions Parshant Dhand FLUENT 2 January 10, 2003 21:25
Boundry Conditions Parshant Dhand FLUENT 2 January 10, 2003 21:18
