DecomposePar and sets
Old   January 2, 2007, 22:35
Juan Hierro
jhierroa is on a distinguished road
I am interested in knowing whether there is any way to work with a mesh divided into different sets (for instance rings around a central cylinder with different transport coefficients) where the final computation of the equations is, moreover, divided into different processors (with divisions along the z axis).
In other words:
Let it be a cylinder with rings around it with different transport properties and each cylinder is modelled by a different set (cellSet is used in the main code to set the transport properties in each ring). Is there any chance to compute the resulting system in parallel?
NOTE: a standard use of decomposePar works fine with everything (faces, nodes, points, patches, ...) except for the definition of the different sets which are not decomposed among the different processors.
Last edited by wyldckat; April 27, 2019 at 15:54. Reason: merged posts that were identical
jhierroa is offline   Reply With Quote
Old   January 3, 2007, 06:52
Default decomposePar does decompose zo
Mattijs Janssens
mattijs is on a distinguished road
decomposePar does decompose zones (cellZones, faceZones, pointZones). Run setsToZones to convert your sets to zones and use e.g. the 'zoneToCell' cellSet source to convert back.
mattijs is offline   Reply With Quote
Old   January 3, 2007, 10:23
Default Hi Juan! I have written a s
Assistant Moderator
Bernhard Gschaider
Hi Juan!
I have written a small modification to decomposePar that decomposes the sets as well. If you're interested, send me a mail.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 3, 2007, 17:06
Default Yes, I am interested in that s
Juan Hierro
Yes, I am interested in that small modification. I have already sent you a mail.
Old   January 15, 2008, 08:53
Default Hi Bernhard, This post is
Frank Bos
lr103476 is on a distinguished road
Hi Bernhard,
This post is quite old, but I'm also interested in the modification of decomposePar to decompose cellSets......Could you post it here ?
Thanks and regards, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   January 15, 2008, 15:18
Default Hi Frank! I've adapted it
Assistant Moderator
Bernhard Gschaider
Hi Frank!
I've adapted it to compile on 1.4.1 (due to that it won't compile on 1.4 or lower) and put it on the svn on openfoam-extend. You can get it (and a test-case) with this command:
svn checkout https://openfoam-extend.svn.sourcefo...oseParWithSets
As an alternative I'll attach a patch here that contains all the necessary changes to the original decomposePar-sources and should work on 1.3 and 1.4 too.
I havn't used the modification in a long time, but it still seems to work
Bernhard
domainDecomposition.C.patch
Old   January 15, 2008, 18:05
Default Thanks Bernhard! It seems
Frank Bos
Thanks Bernhard!
It seems to work. I now have decomposed a case with two mesh subsets, but something real strange occurs:
The wing motion of the same case with 2 subsets is different in parallel compared to the serial case. Very strange, but at least I can decompose now.....thanks for that.
Frank
Frank Bos
Old   January 25, 2008, 10:48
Default Hi I've tried setsToZone but
Christofer Ivarsson
cricke is on a distinguished road
Hi
I've tried setsToZone but then get problems with memory allocation?!
Where do I compile the domainDecompositiion.C.patch file? Does it affect my original decomposePar or can I switch back if it doesnt work? What command to execute the new decomposePar?
RG
Christofer Ivarsson
cricke is offline   Reply With Quote
DecomposePar utility hsing OpenFOAM Running, Solving & CFD 11 January 19, 2015 05:09
DecomposePar jadavis1 OpenFOAM Running, Solving & CFD 0 January 28, 2009 16:07
DecomposePar and mergePatchPairs hannes OpenFOAM Bugs 4 June 26, 2007 13:01
