September 12, 2024, 04:48 |
fvSchemes Error
Priyank
I am working on a case setup of flow over a cylinder, solver used is simpleFoam and model is kwsst.
I have used limitedLinear scheme in fvSchemes dict. after running simpleFoam it shows this error: Wrong token type - expected word, found on line 48. Error is in fvScheme dict but not able to find. pls help. Also attaching my fvSchemes dict. |
September 16, 2024, 05:45 |
Rep Power: 2 |
Sometimes there are some characters that appear in the file but are not visible to the user. You can use different document viewers to identify them or copy paste the contents and error in chatgpt and see if it's an issue like that
Yesterday, 10:16 |
Rep Power: 5 |
Hey!
I think there are several mistakes:
fvscheme, gauss limitedlinear 1, limitedlinear, openfoam v2112, second order schems |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
