How to create duplicate patch / create baffle |
September 4, 2024, 10:15 |
Ibrahim I
Rep Power: 2 |
Hello, I have a mesh from gmsh and imported it into openfoam. I have an internal wall which is defined as a patch boundary and I need to make it into a baffle.
Does anyone know how to create a duplicate patch / make a baffle from this ? E.g. from toposet. So far I've used toposet patchToFace and FaceToFace to create 2 facesets of the same patch. But when running createpatch for these 2 sets it only does one because it says it's the same faces. Do I need to flip the orientation of one of them ? Or what's the process of creating a baffle starting from a single patch ? Thank you |
September 4, 2024, 11:14 |
Yann
Rep Power: 27 |
I think this is a job for the mergeOrSplitBaffles utility in the OpenCFD branch (openfoam.com) and OpenFOAM foundation branch (openfoam.org) up to OpenFOAM-8. For the foundation branch, it has been deprecated for the new splitBaffles utility since OpenFOAM-9. Cheers, Yann |
[Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 6 | January 12, 2021 05:55 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
