August 26, 2024, 05:21 |
Pipe flow turbulence modeling
Hyun Jung Lee
Good afternoon guys.
I'm a new user of SedFoam model to simulate pipe flow with sediment. I just want to validate the model to check non-deposition condition. I set 0.02 m/s for fluid and sediment's velocity and the others were not editted. For the simulation time was set to endTime 30, writeInterval 0.3, but the simulate was terminated at 16.442 s with very small delta T and high max epsilon.b, k.b, nut.b, Ua and Ub. Could you help me to solve these problems? Or It would be really helpful if you correct me about patches' type or values. Thanks..! object p_rbgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } wall { type zeroGradient; } } // ************************************************** *********************** // object Ua; (Ub was same) } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.0 0 0); boundaryField { inlet { type fixedValue; value uniform (0.02 0 0); } outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } wall { type noSlip; } } // ************************************************** *********************** // object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; internalField uniform 2.98e-9; boundaryField { inlet { type fixedValue; value uniform 2.98e-9; } outlet { type inletOutlet; inletValue $internalField; } wall { type epsilonWallFunction; value $internalField; } } // ************************************************** *********************** // object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 1.5e-6; boundaryField { inlet { type fixedValue; value uniform 1.5e-6; } outlet { type inletOutlet; inletValue $internalField; } wall { type kqRWallFunction; value uniform 0; } } // ************************************************** *********************** // object muI; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0.01; boundaryField { inlet { type fixedValue; value uniform 0.01; } outlet { type zeroGradient; } wall { type zeroGradient; } } // ************************************************** *********************** // object alpha_a; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0.010119; boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } wall { type zeroGradient; } } // ************************************************** *********************** // |
boundary condition, input, patch, sedfoam, turbulence |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 18:22 |
Turbulence Modeling - The Gist | Avr.Tomer | Main CFD Forum | 0 | September 28, 2019 00:13 |
Turbulence intensity in fully devloped pipe flow - Reference | Shocktrain | Main CFD Forum | 0 | October 14, 2010 07:58 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 21:28 |
Turbulence model for Transient Pipe Flow Modeling | Brian | FLUENT | 0 | June 7, 2002 13:15 |
