Optimizing Cell Weight for Mesh Decomposition in OpenFOAM
Old   August 13, 2024, 11:23
Default Optimizing Cell Weight for Mesh Decomposition in OpenFOAM
Dimas
dimasbarile is on a distinguished road
Hi everyone,
I'm running a case with 60 topoSet boxes distributed throughout the domain, where each set is read by the fvOptions file to introduce a source term. I want to use "scotch" method for decomposition. Because of the way the source term is written it is much faster for the simulation to achieve 2 things in mesh decomposition:
1- Ensure that none of the sets are split across processors.
2- Balance the number of sets across processors as evenly as possible.
I've already addressed the first issue by applying constraints in the decomposeParDict file. However, I'm struggling with the second point. Is there a way to modify the weight of each cell so that the cells in a topoSet have a higher weight, and the domain is decomposed accordingly? I've explored the "strategy" option in Scotch, but haven't found a solution.
Any advice or suggestions would be greatly appreciated!
Thanks!
dimasbarile is offline   Reply With Quote
decomposepar, mesh, scotch, weights
UDF in case with DPM modle POSTHU Fluent UDF and Scheme Programming 0 March 3, 2021 08:21
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 6, 2018 00:48
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 15:38
Warning 097- AB Siemens 6 November 15, 2004 05:41
