Problem when running potentialFoam for francis99 turbine |
August 11, 2024, 11:18 |
Rep Power: 2 |
I'm trying to run Francis99 turbine case. At the first step of running my case I have to run potentialFoam solver which gave me this error:
Create time Create mesh for time = 0 Initializing the GGI interpolator between master/shadow patches: RU_PER2_31/RU_PER1_32 Initializing the GGI interpolator between master/shadow patches: RU_PER2_40/RU_PER1_41 Initializing the GGI interpolator between master/shadow patches: RU_PER2_48/RU_PER1_49 Initializing the GGI interpolator between master/shadow patches: RU_PER2_52/RU_PER1_53 Initializing the GGI interpolator between master/shadow patches: RU_PER2_54/RU_PER1_55 Initializing the GGI interpolator between master/shadow patches: GV_PER2_4/GV_PER1_5 Initializing the GGI interpolator between master/shadow patches: GV_PER2_12/GV_PER1_13 Initializing the GGI interpolator between master/shadow patches: GV_PER2_22/GV_PER1_23 --> FOAM FATAL IO ERROR: keyword potentialFlow is undefined in dictionary "/mnt/k/openfoamorg_pg/Project/FOAM-extend-3.2ExampleCases/GVRUDT_MP_FOAM-extend-3.2/F99MP/system/fvSolution" file: /mnt/k/openfoamorg_pg/Project/FOAM-extend-3.2ExampleCases/GVRUDT_MP_FOAM-extend-3.2/F99MP/system/fvSolution at line 21. From function Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) in file db/dictionary/dictionary.C at line 658. FOAM exiting Then I added this dictionary to fvSolutions: Code:
potentialFlow { nNonOrthogonalCorrectors 0; } which gave me this error: Code:
Create time Create mesh for time = 0 Initializing the GGI interpolator between master/shadow patches: RU_PER2_31/RU_PER1_32 Initializing the GGI interpolator between master/shadow patches: RU_PER2_40/RU_PER1_41 Initializing the GGI interpolator between master/shadow patches: RU_PER2_48/RU_PER1_49 Initializing the GGI interpolator between master/shadow patches: RU_PER2_52/RU_PER1_53 Initializing the GGI interpolator between master/shadow patches: RU_PER2_54/RU_PER1_55 Initializing the GGI interpolator between master/shadow patches: GV_PER2_4/GV_PER1_5 Initializing the GGI interpolator between master/shadow patches: GV_PER2_12/GV_PER1_13 Initializing the GGI interpolator between master/shadow patches: GV_PER2_22/GV_PER1_23 Reading field p Reading field U Initializing the mixingPlane interpolator between master/shadow patches: GV_OUTFLOW_1/RU_INFLOW Initializing the mixingPlane interpolator between master/shadow patches: RU_OUTFLOW/DT_INLET Calculating potential flow BiCGStab: Solving for p, Initial residual = 0, Final residual = 0, No Iterations 0 continuity error = 0 --> FOAM FATAL ERROR: evaluate() cannot be called for a genericFvPatchField (actual type rotatingWallTangentialVelocity) on patch GV_INFLOW_9 of field U in file "/mnt/k/openfoamorg_pg/Project/FOAM-extend-3.2ExampleCases/GVRUDT_MP_FOAM-extend-3.2/F99MP/0/U" You are probably trying to solve for a field with a generic boundary condition. From function genericFvPatchField<Type>::evaluate(const Pstream::commsTypes) in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 757. I should say that case has a custom boundary condition that is included with the case file. I' had tried to use it by compiling that with "wmake libso" original case is built with FOAM-extend 3.1 I don't know where is the problem & I appreciate any help. |
August 15, 2024, 13:59 |
Rep Power: 2 |
For those who may come up with this problem, the Last error belongs to the implemented boundary condition. I recompiled the boundary condition error was solved:
wmake libso What is the difference between "wmake" & "wmake libso"? |
custom boundary condition, foamextend, francis, potentialfoam |
Problem in meshing and running rotating geometry case with AMI with OF-5 | atul1018 | OpenFOAM Running, Solving & CFD | 0 | April 3, 2024 06:11 |
[blockMesh] Problem with running blockMesh | yoshiyagi | OpenFOAM Meshing & Mesh Conversion | 3 | November 2, 2022 23:49 |
Problem with forces and moment calculated for wind turbine blade using simpleFoam | mostafa kamal | OpenFOAM Running, Solving & CFD | 2 | September 21, 2021 17:33 |
Vertical axis wind turbine - GGI problem | Piotr Zwolinski | CFX | 1 | January 12, 2014 06:01 |
problem running potentialFoam | sidmajor | OpenFOAM Running, Solving & CFD | 8 | May 3, 2013 14:48 |
