CHT splitting one of the internal faces in two |
Karol Celinski
Rep Power: 2 ![]() |
I have a geometry of the pipe surrounded by water I calculated the value of omega at the inside of the pipe. However value at the edge of the pipe and on the outside should be different. Is it possible to split one of the internal faces (in between two regions) for example called inletPipe_to_water into two separate boundaries so I can apply different boundary conditions on the inside and outside of the pipe. |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
[snappyHexMesh] layer not added | Rasmusiwersen | OpenFOAM Meshing & Mesh Conversion | 1 | January 2, 2020 09:43 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
