Dasha
Rep Power: 2 ![]() |
I'm setting up a multi-region heat exchange case and I have a question about the dimensions of turbulent thermal diffusion. According to the documentation (see link 1 and link 2) : Code:
alphat | Kinematic turbulent thermal conductivity [m2/s] However, in the tutorials, I found that the units are given as kg/m/s: Code:
FoamFile { format binary; class volScalarField; location "0/fluid"; object alphat; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 1 -1 -1 0 0 0 0 ]; I'm also found a post with the same question, but without an answer. Useful links: https://cfd.direct/openfoam/free-sof...or-the-future/ https://en.wikipedia.org/wiki/Turbul...Eddy_viscosity |
alphat, thermal diffusion |
fvOptions() Options and SemiImplicit Source Term - Units | Tobi | OpenFOAM Programming & Development | 11 | February 18, 2021 09:13 |
Thermophysical Property Units | johanz | OpenFOAM Pre-Processing | 2 | December 16, 2018 10:08 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
mut and alphat & compressible flow | sasanghomi | OpenFOAM | 2 | September 17, 2013 14:42 |
units in OpenFOAM | megacrout | OpenFOAM | 4 | July 19, 2011 08:04 |
