Charalampia Filippatou
Rep Power: 2 ![]() |
Hello! I'm reaching out to the cfd community for help with a case. I'm trying to simulate the flow around the onera-m6 wing with turbulence model. However I'm getting the same error:
[1] #0 Foam::error: ![]() [1] #1 Foam::sigFpe::sigHandler(int) at ??:? [1] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 ? in "/lib/x86_64-linux-gnu/libm.so.6" [1] #4 Foam::hePsiThermo<Foam: ![]() ![]() ![]() [1] #5 virtual thunk to Foam::hePsiThermo<Foam: ![]() ![]() ![]() [1] #6 Foam::solvers::fluid::thermophysicalPredictor() at ??:? [1] #7 ? in "/opt/openfoam11/platforms/linux64GccDPInt32Opt/bin/foamRun" [1] #8 ? in "/lib/x86_64-linux-gnu/libc.so.6" [1] #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [1] #10 ? in "/opt/openfoam11/platforms/linux64GccDPInt32Opt/bin/foamRun" [optiplex:712320] *** Process received signal *** [optiplex:712320] Signal: Floating point exception (8) [optiplex:712320] Signal code: (-6) [optiplex:712320] Failing at address: 0x3e8000ade80 [optiplex:712320] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x75da60e42520] [optiplex:712320] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x75da60e969fc] [optiplex:712320] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x75da60e42476] [optiplex:712320] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x75da60e42520] [optiplex:712320] [ 4] /lib/x86_64-linux-gnu/libm.so.6(+0x1349c)[0x75da6212c49c] [optiplex:712320] [ 5] /opt/openfoam11/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThe rmoINS_9psiThermo9compositeENS_11pureMixtureINS_19 sutherlandTransportINS_7species6thermoINS_12hConst ThermoINS_10perfectGasINS_6specieEEEEENS_22sensibl eInternalEnergyEEEEEEEE9calculateEv+0xe3d)[0x75da56836c3d] [optiplex:712320] [ 6] /opt/openfoam11/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZTv0_n72_N4Foam11 hePsiThermoINS_9psiThermo9compositeENS_11pureMixtu reINS_19sutherlandTransportINS_7species6thermoINS_ 12hConstThermoINS_10perfectGasINS_6specieEEEEENS_2 2sensibleInternalEnergyEEEEEEEE7correctEv+0x35)[0x75da5683aa85] [optiplex:712320] [ 7] /opt/openfoam11/platforms/linux64GccDPInt32Opt/lib/libfluid.so(_ZN4Foam7solvers5fluid23thermophysical PredictorEv+0x546)[0x75da5e03c686] [optiplex:712320] [ 8] foamRun(+0x3fb8)[0x60162db52fb8] [optiplex:712320] [ 9] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x75da60e29d90] [optiplex:712320] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x75da60e29e40] [optiplex:712320] [11] foamRun(+0x4765)[0x60162db53765] [optiplex:712320] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 1 with PID 0 on node optiplex exited on signal 8 (Floating point exception). Chat gpt suggested that i add the following lines to m controlDict: equationOfState { rho rho; } specie { T 300; Cp 1004.5; } Does anybody have an idea on how to fix the error and reach the wanted convergence? Thank you in advance guys! |
Openfoam sometimes gives floating point exceptions when the mesh quality is not good enough. Have you run checkMesh? If the mesh is okay, I suggest you have a look at this: https://baramcfd.org/tutorials/2024/03/21/onera-post/ Baram flow is a really nice interface for OF. You can translate the page to English to check your settings with their tutorial. I hope this helps |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 12:16 |
Calculating the Reynolds Number of the largest eddies in a turbulent flow | rdemyan | Main CFD Forum | 8 | February 14, 2023 04:23 |
Why can i use a laminar solver for a turbulent flow? [Heat transfer problem] | blackbow | CFX | 1 | November 22, 2016 04:42 |
Difference between recirculation zone and turbulent flow region | ashtonJ | Main CFD Forum | 0 | September 16, 2011 03:46 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
